Best fit and forget...
[Closed] Best fit and forget brakes
Am looking for new brakes as I can't get my IS maguras to fit my forks. I'm not arsed with adjustability, just want something that I can stick on easily enough and they just work and are reliable. Had Hopes (ok) and Avids (hated them) in the past but both needed messing with from time to time whereas the maguras were just fit and forget.
I know more maguras would be the way to go but what else fits the above?
Posted : 30/10/2012 1:08 am
Nothing's truly fit and forget, Maguras do go wrong too- yours didn't but another set might (or your current set might have popped tomorrow)
Best reliability I've had was from Formula Oros, which I didn't really expect tbh but I ran 4 sets and never had any problems with any, despite some of them being absolutely ancient.
Posted : 30/10/2012 1:12 am
For me it's Hope all the way. Occasional bleed - same with all brakes really.
YMMV
Posted : 30/10/2012 1:13 am
Never had to even bleed any of my Shimano brakes ,SLX and Saint.As for Avids... 👿
Posted : 30/10/2012 1:16 am
Hope m4s.best brakes I've ever used...fit and forget..pads last ages....awesome!
Posted : 30/10/2012 1:17 am
For balance I've had 2 sets of elixirs fir several years and they've been flawless.
Posted : 30/10/2012 7:51 am
Hope for me. Mono Minis then Tech X2 and now Tech M4. Bleed once a year to keep them perfect and that it. Always found Shimanos got sticky piston syndrome after a few months winter riding - bit of faff to sort them. TBF that was some time ago
Another point about Hope is that the whole handlebar unit seems very resilient to crash damage. Even the levers will just bend back happily
Posted : 30/10/2012 8:00 am
Formula? My R 1's have been faultless.
Posted : 30/10/2012 9:22 am
My XT's (new ones and the previous version) have been really. really good. Done nothing to them after the initial bleed other than chuck new pads in every 6 months. For me, everything I can have will be shimano, it just works.
Posted : 30/10/2012 9:27 am
 ffej
My Formula Oros were perfect for 3 years. Excellent power and modulation. Would buy Formula again without a problem.
Posted : 30/10/2012 9:28 am
My vote, for best-value fit-and-forget brakes, goes to Shimano SLX.
Posted : 30/10/2012 9:48 am
As always, I shall say BB7.
Posted : 30/10/2012 9:52 am
SLX. Can't be beaten for the money and maintenance free.
Posted : 30/10/2012 9:55 am
Shimano SLX
Formula RX - needed a bleed after almost 2 years and have used a couple of sets of pads but that's it. They just get on with business.
Posted : 30/10/2012 9:57 am
Just for balance, my slx were terrible. They just kept leaking to the point where after about 2 months the rear was empty of fluid. Power was woeful as most of the fluid ended up on the rotors.
Posted : 30/10/2012 10:05 am
 pdV6
Current bike has Hope Tech X2's on it.
In 3 years, the only time I've touched them is to replace the pads in the rear.
Posted : 30/10/2012 10:14 am
M6TTF - Member
Same here. Had them on both bikes for years and never had an issue. Which is just as well, as I tend to have a 'trust in God and everything will be fine' attitude to bike maintenance. And a hammer
Posted : 30/10/2012 10:23 am
Saint FTW - my Magura Louise have also been pretty trouble-free.
Posted : 30/10/2012 10:32 am
Have had formulas, XT and Hope V2s before, none come close to the new SLX with Ebc pads.
Posted : 30/10/2012 10:37 am
5 yrs in Jan 2 sets of Formula Oros, been bled once last year didn't need it but thought it was about time. Powerful, simple, reliable and an easy pad change all you need from a set of brakes.
Posted : 30/10/2012 10:39 am
XT
Posted : 30/10/2012 10:41 am
SLX best suited, reliable and maintenance free.
Posted : 30/10/2012 10:42 am
I've got some Deore brakes that are 10+ years old and I've never done anything to them other than changing the pads and some fresh brake fluid when I've been changing cables as they've moved onto different bikes.
I've got 2012 XT and Deore brakes and they've been faultless and need for nothing. Although people did report some problems with the XT ones its not something that has effected me.
As for servicing, the Deore ones are sooooooooo cheap I would just be a hideous consumer and buy a new caliper/mastercylinder etc...
Posted : 30/10/2012 11:07 am
OROS love mine even tho they old and are on their last legs.
Posted : 30/10/2012 12:20 pm
I bought my Minis in 2001. I recently changed the seals & pistons and they're good as new.
Posted : 30/10/2012 12:23 pm
Tektro Aurigas are good at the budget end.
Posted : 30/10/2012 12:24 pm
BB7, i haven't even had to wind my pad adjusters in for a few months. Might just got another for the rear of my bike rather than piss around with slx and their questionable ceramic pistons which I don't have a whole load of faith in any more! My Juicy 5s were really reliable as well surprisingly, just a bit of a hassle to bleed til you got the technique sorted. Really easy to strip down and repair as well.
Posted : 30/10/2012 12:38 pm
back to completely useless then?
Posted : 30/10/2012 12:42 pm
...rather than piss around with slx and their questionable ceramic pistons...
Go on...
Posted : 30/10/2012 12:48 pm
Shimano deore
Posted : 30/10/2012 12:58 pm
I'm with IHN - BB7 for sure! My Formula the ones have been excellent and the original 4 pot XT were more or less bombproof. Hope we're always variable for me although customer service good.
Posted : 30/10/2012 1:03 pm
My workshop experience -
Avid - dont bother, you do get a few lucky ones though, most probably my fave in terms of feel, shape and power though when they're box fresh with a good bleed
Hope - totally rebuildable/serviceable/easy to do but are never really good though, pretty rubbish actually, not worth the money
Formaula - pretty reliable, tight on pad clearance, just keep pistons clean
Magura - fine, service spares is only issue
Shimano - faultless and the consistently best performing, the odd duff set, not surprising the volume i've seen though. cant rebuild them though, but the way things have panned out though, the current deore are easily as good as previous XT
Posted : 30/10/2012 1:13 pm
Canti's? 🙂 Though TBH I can't really remember if they were more or less hassle in terms of maintenance on an MTB.
I've had Elixir and Juicy's which a lot of people whinge about. I've had to bleed them maybe a few times a year and do the usual change of pads. Nothing I wouldn't expect from any other brake system.
Posted : 30/10/2012 1:23 pm
Maintenance is inevitable. Embrace the maintenance and go with Hope. Easy to maintain unlike some others.
Posted : 30/10/2012 1:26 pm
My Oro's needed zero maintenance for 4 years, shame all the bolts were made of cheese which is why I binned them for BB7's
Posted : 30/10/2012 1:33 pm
XTR, never toucched em except for pads. Have the latest model on one bike and the previous on another, faultless after a few years of heavy use.
Posted : 30/10/2012 1:39 pm
Cheap sub deore ones from rosebikes (m445s maybe). £45 the pair still going strong after a year of neglect on winter bike. At that price any issues I'll bin and buy again. Power wise they're fine maybe not quite the power of deore/slx but unless ur doing big DHs.
Posted : 30/10/2012 1:51 pm
Only used older Avids Elixir, Juicy and now Deore
Really liking so far my boggo Deore M596 brakes, running with cheapo superstar pads - cheap, powerful, bleed easily (if needed) and just work. So cheap that a quick google suggests if they do go wrong its not a disaster to pay £20-£25 for a new lever or caliper.
Avid Elixir R's to be fair were even cheaper to buy in the sale and if and its a big if, they do run perfectly provide greater feel and a tad more power with organic pads. However, performance and reliability is too variable, and yes rebuilds can be cheap depending what needs fixing, as they are cheap in the sale to start with, can always just buy a new complete unit.
Posted : 30/10/2012 1:56 pm
Hope for me, had some m4's changed and went through new style XT, elixir 5, formula rx in 5 months now back on hope and not changing again.
Posted : 30/10/2012 2:13 pm
 Euro
Surely 'fit and forget' is down to the owner not the brakes?
My Marin (bought in 07) had Avid Juicy 3s which were forgot about for 4 years - no new pads, fluid, nothing. For two of those years it was my only bike and got used for everything and they worked great. A friend was changing pads on a different set of brakes and I thought i'd have a look at mine. Obviously all 4 pads were worn to the metal, but they still worked. Proper fit and forget.
Posted : 30/10/2012 2:29 pm
 sbob
Leftfield choice: Magura rim brakes. I think the ones I have are 17yrs old.
My 12yr old Formulas are still good.
Posted : 30/10/2012 2:33 pm
Another vote for Formula Oro's. I installed mine 4 years ago, have changed the pads a couple of times and that's it.
I should probably bleed them at some point.
Posted : 30/10/2012 2:36 pm
I havent had any issues with my new shape XTs and have been my favourite brakes to date.
Not had issues with juicy 7, Hayes 9 either but have had a nightmare with Elixiers and hopes.
Posted : 30/10/2012 2:44 pm
I have the latest XTR and I loved them. Then both front and rear pistons popped, pissing oil everywhere. Ruined the pads and you can't repair the caliper. Not amused in the slightest because they were truly awesome, but I can hardly call them fit and forget.
Posted : 30/10/2012 2:57 pm
I've had several sets of Shimano brakes of various models and never had any issues with them. Consistent performance and totally reliable.
I've been using Hayes Stroker Trails for about four years and now have them on four bikes. Dead cheap, zero maintenance and great performance.
Posted : 30/10/2012 2:58 pm
Very tempted to try Shimano, seem to fit the bill.
What's the difference between XT & XTR? Not necessarily the current model, just in general terms with regards disc brakes?
Posted : 30/10/2012 3:53 pm
What do you mean popped, as in popped out or the seals went on them?
Posted : 30/10/2012 4:32 pm
Hope for me. Plenty enough stopping and even I can maintain them. Brilliant after-sales service / help.
Posted : 30/10/2012 5:02 pm
Shimano.
I have some Deore M525s that have been on three bikes ~5 years old. I've never bled or done any maintenance on them apart from change pads, and once changed worn rotors. They seem to work just fine.
I now have SLX M666's on my FS bike; the bite and power is awsums. Hoping they are similarly reliable.
EDIT. I lie... I smashed the left lever assy in a crash a couple of years back and the bike shop fitted replacements, so they have been bled once.
Posted : 30/10/2012 5:06 pm
 hora
Shimano Servowave XT's. I've had them going on two years soon. I've not touched them once. No idea what the screws ontop do either!
Posted : 30/10/2012 5:12 pm
Go on...
I may have just got a dodgy set but when pushing my pistons back in with the pads still in (screwdriver between the pads), one of them managed to crack and piss fluid everywhere. It did need a lot of force so hopefully a warranty job although I'm still yet to hear back from Rose regarding this. I now don't really trust the one that does work!
Anothing thing about shimanos is that their levers look gash.
Posted : 30/10/2012 6:27 pm
