Best 16g CO2 inflat...
[Closed] Best 16g CO2 inflator for using Cheap Cartridges?
[#743642]
I have an Innovations Proflate 16 inflator (bought in an emergency!). It only uses Innovations cartridges (expensive) and doesn't work with the cheapo cartridges that are available. Can anyone recommend a similar inflator that works with cheapo CO2?? cheers.
Posted : 29/07/2009 9:42 am
i just got the cheapest one from http://www.tyreinflators.co.uk/
Posted : 29/07/2009 9:44 am
Which model? Does it hold the co2 for more than 1 shot?
Posted : 29/07/2009 9:54 am
http://www.tyreinflators.co.uk/cls-tyre-inflators/mosa-co2-mini-inflator-inc-2-x-16gm-threaded/prod_269.html
I think so, not sure though - not used it that much tbh
Posted : 29/07/2009 9:56 am
 Aidy
What's the difference between innovations cartridges and other cartridges?
Posted : 29/07/2009 11:03 am
I got the same one as grumm - works really well so far.
Posted : 29/07/2009 11:10 am
 Smee
Have you tried the cheaper cartridges in it. or are you just taking their word for it?
Posted : 29/07/2009 11:16 am
http://www.tyreinflators.co.uk/innovations-tyre-inflators/innovations-ultraflate-plus-includes-1x16gm-uses-only-innovations-brand-co2/prod_565.html I've got this one, and use the cheap cartidges, seems spot on to me...
Posted : 29/07/2009 11:20 am
I use an Innovations Microflate, it's very easy to modulate, I'd avoid any with any sort of 'trigger' they're always plasticy and nasty!
Posted : 29/07/2009 11:22 am
Think the non fitting bit refers to unthreaded cartridges only on most of these. If you use threaded so far all that I have used have been OK.
Posted : 29/07/2009 11:46 am
I have tried non Innovations unthreaded cartridges in my Proflate 16 - the dimensions must be a nano bit larger on the Innovations ones. Result is that cheapo cartridge mustn't sit quite right in Innovations inflator - just gives a sharp cold PHHHWWWSSSSSSSSHHHHHHH of the ol' CO2 all over the place.
Posted : 29/07/2009 9:56 pm
