Belt-Drive Full sus...
[Closed] Belt-Drive Full sus update
45 Users
^^^ Nice!!!!!
Posted : 03/11/2010 2:29 pm
that pinion looks excellent
combine it with a belt drive and itll be like riding the bike of the future, today!
Posted : 03/11/2010 2:34 pm
Rohloff get 14 gears into a 'gearbox', although chain driven at present.
When I said 'shaft driven' I meant a car or motorbike style one. Rohloff is an epicyclic gear system and is therefore inefficient in terms of power transfer.
The pinion thing could be either, I dunno.
Posted : 03/11/2010 2:47 pm
the pinion box is a motorcycle style one but with 3 shafts not two to allow lots of gears without it getting too wide
Shaft drive is inherently inefficient as the drive has to turn thru 90 degrees twice. In motorcycles you loose about 10% of the power
Posted : 03/11/2010 3:09 pm
strictly speaking you could fit other types of sprocket to the thread...
they claim ~96%+ efficiency - certainly the hub never got warm
Posted : 03/11/2010 3:12 pm
I think the transmission of the future is chain drive, but totally encased in an oil bath chaincase like Sunbeams in the past or Katz bikes right now. We could run much lighter chains and sprockets.
However as long as we run exposed transmissions, belt is the way to go.
The advantage of a rear hubgear over gearboxes is that the torque is stepped down between the crank and the rear wheel so the gears can be lighter.
Doing a step down between the crank and a centrally mounted gearbox suffers from the lack of room to do it and also introduces another set of drivetrain losses.
If you don't have a stepdown then you need stronger gear components which is difficult to do without a significant weight penalty - probably close to 100% at a guess.
Any idea of the weight of those centre mounted gears?
Posted : 03/11/2010 5:05 pm
That Pinion looks great.
Someone tell me one of those at the fron and a Rohloff at the back wouldn't work for a 252 speed( minus some overlaps probably, but we still count them in a 27sp system) bike? What would be the effective range there?
Posted : 03/11/2010 9:34 pm
Half term again?
Posted : 03/11/2010 9:43 pm
andrewh - Member
Not as light as combining a Cambio Gear 16 speed front and a Rohloff 14 speed.
I have both and occasionally feel tempted to put them together.
I think the Pinion weighs half a ton though.
Posted : 04/11/2010 1:44 am
Please do, I would love to see that.
Posted : 04/11/2010 1:53 am
I've been thinking about this, and I don't think it holds water - if you only have one front and rear sprocket, it's not much of a weight penalty to have them both quite large, and the torque situation is no different to singlespeeding - apart from the possibility of pedalling up much steeper stuff than normal singlespeeders...
Posted : 04/11/2010 6:49 pm
The Rohloff gear hubs have a 2:1 limit.
Posted : 04/11/2010 7:10 pm
Pinion: [url] http://www.pinion.eu/en/faq.html [/url]
[i]"In its present form, the P-1, including chainwheel, without cranks weights approx. 2.7 kg."[/i]
That's about 1kg heavier than the Rohly. But the CoG is in a better place.
Posted : 04/11/2010 8:06 pm
Yes, not too bad. Any word about how much backlash there is in it?
Posted : 04/11/2010 11:06 pm
how is this relevant ? They're not designed for BB mounting anyway
Posted : 04/11/2010 11:46 pm
I'm just doing a project at work (engineering consultancy) reviewing different gearbox / drive systems for bikes. We have come to the conclusion that there is a reason that chains have been used for so long and will continue to be. They are cheap have good efficiency and allow for a lot of misalignment. Geared systems need comparativly high levels of accuracy in their machining and mounting. Plus you get issues with most of the load being taken by one tooth. This is why planetary gears are used, so the load is shared by more teeth. Yes you could make the gears from stronger material (and case harden it), but then it needs refinishing due to distortion. The cost of gears goes up and up, compared to bits of stamped out steel.
Systems like the Pinion may be very good for a few bespoke manufacturers, but until the big boys (i.e Giant) start making thousands of bikes that use systems like it, the humble BB and chain/deraileur system will continue to be used.
The Alfine system will start to be used more and more I think, and having it linked to a belt drive does make sense to me.
Posted : 05/11/2010 12:01 am
simonfbarnes - Member
'The Rohloff gear hubs have a 2:1 limit.'
The relevance is that a heavy gear system would have to be even heavier to be used in that situation. I believe someone has prototyped a Rohloff in that position.
Posted : 05/11/2010 8:06 am
That was how the first G-Boxx's were designed, a frame-mounted Rohloff.
If a frame-mounted Alfine could be sorted out, especially one that could be retro-fitted, it could be a good thing. But would probably by ugly as sin.
Bear - get onto it then!
Posted : 05/11/2010 11:38 am
we've looked into using belts for some time and it's only just getting commercial now. we did also work on a gearbox hardtail idea that used the mount points for the gearbox as a way to have a Fisher CR-7 style mix of ti and aluminuim in the frame. but all in all, i couldn't imagine it being a better ride than an equivalently priced hardtail with xtr... it's good to work on these things to drive the industry forward, but if nicolai can't make a gearbox system that appeals to the masses i don't know who can. mechs and hub gears are the options that are here to stay for a long time yet.
actually having written that, i think of the Honda RN-01. it was made somewhere we have good links with. a great bike.. and they considered all kinds of transmissions, and what did they do? move the rear mech and cassette into the centre of the frame and enclose it in a box. it may have been a side-proect or engineer training but it was a brilliant conclusion imo.
simple and the best way forward i think. and, relatively easy to make and bodge into a frame. add a belt to transmit power from the box to the hub maybe, but call me old-fashioned, as much as i like belts i still would go for a simple chain on my own bike. i can't think of a good reason not to. they just work and are easy to work with.
Posted : 05/11/2010 2:27 pm
I'm surprised that nobody has come up with a good CVT system using a belt yet.
Posted : 05/11/2010 2:30 pm
CVTs are horribly difficult to get working correctly with any amount of torque, and torque is something cyclists have by the shed full.
Posted : 05/11/2010 2:34 pm
Shimano?
Posted : 05/11/2010 2:38 pm
er yes, maybe ) or probably, but although Shimano engineers are famous for giving nothing away, i get the impression that they don't see it as viable or worthwhile yet. tbh SRAM are more likely to do it first. Nicolai have a willingness to do something different and make it work as well as they can yet it's been a side-line idea for a long time now.
what i'm getting at is that nicolai have all the engineering intelligence to make systems like this work, yet their best efforts so far don't match an SLX drivetrain imo for general use. to make it more popular as a concept needs a lot less wight and more direct feeling, better efficiency etc.
maybe a shimano 2x10 'mech-in-a-box' is the best way then?
Posted : 05/11/2010 4:26 pm
Ellsworth do a CVT. I forget what its called.
James, how about an Alfine-base G-Boxx? Let me have a sample (or two) and I'll sort it out for you 🙂
Posted : 05/11/2010 8:05 pm
gearbox on the RN-01 is specific because it is not a classic gearbox like the Rohloff Speedhub for instance. It is commonly thought that inside the gearbox there is a classic derailleur, a cassette and a chainring. This is actually not the case. This explanation is a coverup for the actual design of gearbox, the design of which is for the most part, unknown. The freewheel is not placed on the rear wheel but in the bottom bracket so the chain is constantly moving when the back wheel is spinning.
Wikkipedia. Must be true.
Posted : 05/11/2010 8:59 pm
That doesn't look heavy at all. Oh no.
Posted : 05/11/2010 9:29 pm
Just found this too:
Posted : 05/11/2010 9:36 pm
james-o - Member
...i think of the Honda RN-01. it was made somewhere we have good links with. a great bike.. and they considered all kinds of transmissions, and what did they do? move the rear mech and cassette into the centre of the frame and enclose it in a box...
That makes a lot of sense. It's hard to make a gear system lighter than a derailleur setup, and there's nothing wrong with chains so long as they are well lubricated. Back in the days of oil bath chaincases it was not unheard of to get 20,000 miles or more out of a chain.
With a carbon fibre monocoque frame designed to contain such a setup, there should be no weight penalty. There would still be the extra drive train, but it could be compact and contained in an oil bath chaincase like the Katz.
Until that happens though, I'm going to continue aiming for belt drive solutions.
Posted : 06/11/2010 10:34 am
[url= http://www.srsuntour-cycling.com/dstore/products/V-BOXX/2954/GB10-VB-FR9-BAZ/GB10-VB-FR9-BAZ.html ]gearbox[/url]
but the oil will add to the weight of the product
Posted : 06/11/2010 11:17 am
Having run a hub gear with a chain for over 4 years the only real advantage of the belt seems to be saving a bit of weight and a very small amount of maintenance. My last chain lasted 3 years and the current one has done over a year of off road commuting and general use and I've never done more than wipe it over with a rag and spray it with GT85. I still like the idea of one though.
Posted : 06/11/2010 1:17 pm
R.lepecha - Member
gearbox
That gearbox weighs 4.52kgs!
avdave2 - Member
...My last chain lasted 3 years and the current one has done over a year of off road commuting and general use
Hubgear and SS don't have the chain dangling down next to the road grit and also a straight chainline is much more tolerant of wear, so that's a fair point. But it's even better if you have a belt for the same job, lighter, quieter, and cleaner.
Posted : 06/11/2010 2:39 pm
I agree with you epicyclo I just think that most of the advantage comes from the hub gear itself and the belt only offers a relatively small improvement on top. However once these things are working properly in frames designed rather than adapted for the purpose and the teething problems are ironed out then I'd get the Rohloff converted. The best thing about the belt in my opinion though is that the reduction in weight may encourage more people to try hub gears. And the more people do that then the more time and money the manufacturers will spend in trying to improve them.
Posted : 06/11/2010 4:53 pm
I'm not sure the belt offers any efficiency gains but it certainly doesn't appear to have any negatives there in my experience.
I'm currently using a chain on my Alfine hub and a belt on a single speed and also a 3 speed S-A. I would use a belt for all purposes if it was feasible, but most of all I would prefer a sealed oilbath chaincase - unfortunately with current componentry that is not feasible.
Posted : 06/11/2010 6:12 pm
however once these things are working properly in frames designed rather than adapted for the purpose and the teething problems are ironed out
avdave - that's what I'm doing. 🙂
epicyclo - I hadn't seen the Katz before you mentioned it, but I believe Mike Burrows has made a few along those lines. Nice
Posted : 06/11/2010 9:24 pm
alfine gearbox? if yu have the time and the tools.. ! be nice to move the weight off the rear axle but planetery gears always feel a bit 'soft' to me for some uses, great for some applications but i expect the reason the honda used a mech-in-a-box was the direct feel and efficiency. i think a home-made mech in a box would be more achievable.
but i'll not be bothering ) if it's too filthy for gears, it's SS time.
Posted : 08/11/2010 1:56 pm
I'd like to think having the Alfine gubbins mounted on the frame might make it feel a bit more direct. Just think, you could run a fixie rear wheel if the freewheel is on the frame, keep all the moving parts out of the gunk. Its got potential...
I'd love to get hold of a Pinion though. Combined with a Katz and a belt-drive...
Posted : 08/11/2010 6:40 pm
UPDATE!:
[url= http://farm6.static.flickr.com/5213/5489727613_29693306f2.jp g" target="_blank">http://farm6.static.flickr.com/5213/5489727613_29693306f2.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/5489727613/ ]DSC_0405[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
will get the rest of the bike back together over the next few days and report back...
Posted : 02/03/2011 9:41 am
looks industrial but good. I want one for my trance but they (belt drives) don't take well to tensioners
Posted : 02/03/2011 10:09 am
It'll not work on a Trance - you can't change the belt length.
This is on a Kona A which has a concentric pivot around the BB.
Posted : 02/03/2011 10:15 am
I know, hence the comment about the tensioner.
Posted : 02/03/2011 10:23 am
thepodge - Member
My understanding is that there is not a lot of chain "growth" on the Trance or Anthem, so it would be interesting if someone measured that, because it may be possible to belt drive one if it is just a few mm.
Posted : 02/03/2011 11:19 am
Has anyone tried putting a tensioner on a belt drive?
I realise a singlespeed-style tensioner at the rear won't work but what about a tensioner at the crank end or halfway along the suspension arm? Surely you'd be able to get enough length change? (This is total armchair engineering, I don't even know how much chain stretch is require for a short travel full susser!)
Posted : 02/03/2011 11:32 am
I've always quite fancied trying a belt drive on my bike. I haven't been able to find out where to get Rohloff suitable parts though; not that I've been trying particularly hard...
Posted : 02/03/2011 11:59 am
V8 - tensioners won't work as the belt can't be bent backwards.
I guess you could use a reverse sprung one though, as long as you still get adequate belt-wrap on the sprocket.
timangus, fitting the belt to a Rohly is a bit of a faff. Rohloff wil only change the fitting kit themselves (its not just a case of whipping the cog off), and only if you're putting it onto a certified frame design. They claim its to do with frmae stiffness, which I believe to be as much an issue with a singlespeed as a Rohly. I suspect its more the Rohloff can't handle the potential torque "bursts" caused by the belt ratcheting, which is why you have to fit a snubber. Also the Rohly can't handle the recomended tension, hence having to run it slacker which increases the chances of ratcheting. Vicious circle! Especially since the Gates snubber design is pants and can't handle the stresses caused by the belt climbing off the teeth as I've demonstrated. However, I have seen it done:
[url= http://farm6.static.flickr.com/5127/5279764790_365f7f38f6.jp g" target="_blank">http://farm6.static.flickr.com/5127/5279764790_365f7f38f6.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/trafficbikes/5279764790/ ]Dropout Right[/url] by [url= http://www.flickr.com/people/trafficbikes/ ]trafficbikes[/url], on Flickr
Posted : 02/03/2011 12:30 pm
I was thinking something mounted to the chainstay similar to the old DCD but sprung. might work for four bar systems but in the trance the chain goes through the frame and there are no joints / splits / pivots to thread the belt through
Posted : 02/03/2011 12:38 pm
Heh, probably not worth the effort for now then.
Posted : 02/03/2011 1:00 pm
 5lab
out of interest, when using belt drive, why don't the valleys between the teeth on the chainring\sprocket just fill up with mud? Are they hollow underneath or sommit?
Posted : 02/03/2011 1:06 pm
5lab - yeah, they have holes in. Only ridden in mud once (before I bent my previous snubber) and it seemed fine. Time will tell.
timabgus - yeah it is. I've thought about doing it to my Rohloff, but figured its easier not to. So this is being built singlespeed, and I intend to put a belt on an ALfine-11 in the future.
Posted : 02/03/2011 1:17 pm
I figured they would be similar to car cam belts? no problem bending them.
Posted : 02/03/2011 1:55 pm
It says here:
[url= http://www.carbondrivesystems.com/images/uploads/installation_1239728288.pdf ]caution must be used before and during installation to avoid damaging the carbon tensile cords that make up the backbone of the belt’s strength. Excessive bending and twisting creates crimps which can lead to belt breakage under high load.[/url]
Posted : 02/03/2011 2:33 pm
hmmm, i see what you mean, they make it sound as if it is particularly fragile!
Not to worry, it would be a while till I could afford an Alfine 11 for my superlight anyway, i'm just geeking 🙂
Posted : 02/03/2011 3:09 pm
geek out, I say!
Its not that fragile, just doesn't like being bent backwards.
Watch this space for info on my A...
Posted : 02/03/2011 3:44 pm
A tensioner could be rigged up below the front sprocket and push down. It would have to be for a setup with very little chain/belt growth though.
None of my conversions use no more tension than I would use with a chain.
I don't see any point in having the lighter belt drive if I have to have heavier duty components elsewhere.
Fundamental to getting off with low tension are no lateral flex/movement and precise chainline.
Posted : 02/03/2011 7:26 pm
I'm more interested in the lack of maintenance than the weight. so I'd be happy if it weighed a bit more.
Posted : 03/03/2011 8:54 am
ir_bandito - where did you get the Gates parts from?
Posted : 03/03/2011 10:58 am
Bought them direct from Gates Europe. Mrs Nicolai in fact 🙂
email sales@carbondrive.net
delivery from Germany is shocking as they use UPS (£30!). Worth getting together as much of a bulk order as you can to justify it.
I did find a shop in the States selling it the other day
[url] http://www.rememberdelaware.com/m-1097-gates-carbon-drive.aspx [/url]
Don't know how exchange rate and delivery compares cost wise.
Posted : 03/03/2011 11:40 am
UPDATE:
[url= http://farm6.static.flickr.com/5098/5505727994_f88b1c6f9e.jp g" target="_blank">http://farm6.static.flickr.com/5098/5505727994_f88b1c6f9e.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/5505727994/ ]DSC_0407[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
[url= http://farm6.static.flickr.com/5218/5505132039_c3a0b8a3aa.jp g" target="_blank">http://farm6.static.flickr.com/5218/5505132039_c3a0b8a3aa.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/5505132039/ ]DSC_0406[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Assembled last night. To be tested tonight, once the front brake is bled.
Posted : 07/03/2011 9:52 am
[b]IT WORKS!!!!! IT ****IN' WORKS!!!!!![/b]
Happy me.
Posted : 08/03/2011 9:05 am
Posted : 08/03/2011 9:07 am
Nice one! Been following this thread for a while now.
Is that dropout handmade/custom?
Posted : 08/03/2011 9:08 am
Well done. That's a good snubber you have there, should be bulletproof 🙂
Posted : 08/03/2011 9:10 am
what is the A like to ride? do you have to be super smooth? the only people who seem to make bb pivot frames these days are free ride / dirt jump companies.
Posted : 08/03/2011 9:18 am
Chef - yes, I made it with a milling machine and profiled it with a hacksaw.
There was a hint of belt-slipping on a very rough climb last night, which I'm sure still down to frame flex through the pivots. So the next plan is to get another pair of dropouts made to convert thePro2 to bolt thru which shiould stiffen it up a lot more. And while I'm at it, I'll add tensioning bolts, and move the mounting bolt holes so I can get a smidge more tension in the belt.
podge, I'm sure the RP3 shock and SPV forks help with the boingyness. It is a lovely bike. Climbs well and descents are great fun so far.
I would quite like to do a conversion to a Cowan DS, or one of the new Commencals with the concentric pivot...
Albeing well, I'll be riding it at Dyfi.
Posted : 08/03/2011 9:20 am
I think I might just have to find my self a frame. there is a brand new off the shelf Taiwanese one that looks ideal except it has standard vertical dropouts.
Posted : 08/03/2011 9:31 am
ir_bandito most drop outs take 10mm as standard you could upgrade to 10mm bolt up or 10mm through bolt with a DT Swiss QR if you are feeling flush or a superstar one for cheep. There is alot of stories about the 12mm Maxle light breaking and the 12mm hope centre tube failing under load.
Posted : 08/03/2011 9:32 am
I've picked up a 12x135 conversion kit for cheap of the classifieds here, and plan on using the superstar bolt-thru (or original Maxle - not Lite, if I can find one). Syntace would be nice though.
Long term plan is to get some belt-capable frames designed and manufactured, using knowledge gained which I wouldn't have had a clue about otherwise.
After the bolt-thru on the A, I'm going to get an old steel frame and change the dropouts for something a little special that I've come up with 😉
Posted : 08/03/2011 9:43 am
thepodge - Member
Just use a eccentric external BB, eg [b][u][url= http://www.forwardcycle.com/products.html ]the Forward Cycle one[/url][/u][/b].
Where are the frames?
so, one of these:
[url= http://superstar.tibolts.co.uk/images/10mm-QR.jp g" target="_blank">http://superstar.tibolts.co.uk/images/10mm-QR.jp g"/> [/img][/url]
and convert the hub to 10mm, using normal dropouts.
Hmm... its an idea...
Posted : 08/03/2011 9:49 am
would the ebb take the high loading of a belt drive? I can't see why not but then I've never messed with an ebb.
can't remember the name of the frame manufacturer but I have it linked at home, I'll mail you and ir_bandito when I'm back as I might be able to help.
Posted : 08/03/2011 9:50 am
I have my doubts about EBBs and belts, having had a couple of EBBS in the past.
That said, a few manufacturs do them.
Posted : 08/03/2011 9:53 am
Yup one of them there superstar jobbers and one of these
http://www.chainreactioncycles.com/Models.aspx?ModelID=18761
similar to 12mm, still QR = winner. Tis what i have planned for my Iron Horse Mk iii
Posted : 08/03/2011 9:59 am
[url= http://www.tankcycle.com.tw/product.asp?gpid=3&****dno=F000002 ]http://www.tankcycle.com.tw/product.asp?gpid=3&****dno=F000002[/url]
I've seen a few people with prototypes that look exactly the same as this just with different stickers. Spot had one with belt drive at last years expo.
Posted : 11/03/2011 8:17 pm
[url= ]not keen on the wheels but that looks nice.[/url]
Is there any reason you have not used that little roller/tensioner at the front of the drop-out to actually tension the belt same way as they do on cars?
I believe that some of the belt development takes place in the factory along the road from me.
Posted : 12/03/2011 8:42 am
its not a tensioner, its a snubber. i can't remember what its there for
Posted : 12/03/2011 9:16 am
The snubber is there to stop the belt riding up on top of the pulley. It doesn't touch the belt in normal conditions so there is no added friction.
The belt will ride up if the rear cog goes out of alignment with the front, eg during chainstay lateral flex. By having the snubber at the 7 o'clock position it is possible to remove the rear wheel in a vertical dropout with minimal interference from the snubber (the snubber would have to be removed otherwise).
To get a mental picture of what is going on, think of a set of parallel lines arriving to mesh with another set of parallel lines. It only takes a little angular displacement to put that out of sync.
Posted : 12/03/2011 10:46 am
I've actually replaced the roller (standard Gates issue) as it was sticking on the pin (my fault as a tolerance issue) and wearing flat from the belt, rather than turning. Fitted a 2RS bearing which works much better. Now only getting problems with the belt slipping off the side of the pulley occasionally. After having a good look and a ride on the Orange Strange proto, its got two flanges on the pulley, so I might bodge an outer one on...
Posted : 14/03/2011 7:22 pm
In the words of Mr Tong "We Continue!"
The roller worked a treat to prevent ratcheting, but the frame flex meant the belt was still slipping off the side under power. Hopefully converting the Pro2 to bolt thru will reduce that, but in the meantime, I've just made an external flange for the sprocket, from an old cassette.
[url= http://farm6.static.flickr.com/5016/5572694014_9a312df3f4.jp g" target="_blank">http://farm6.static.flickr.com/5016/5572694014_9a312df3f4.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/5572694014/ ]DSC_0468[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Update as soon as I get a chance to ride it...
Posted : 29/03/2011 10:36 pm
On the subject of flanges, despite Gates insisting they're not needed, I've found some Spot branded ones in an online shop, and even in the Gates Carbon Drive parts list, but no mention of them in the instructions...
Centre-Track appeals.
Posted : 29/03/2011 10:39 pm
I love this thread - keep up the good work.
Posted : 30/03/2011 8:58 am
Page 2 / 3
