Bearing replacement...
[Closed] Bearing replacement in DT Swiss rear hub
On a 240S QR disk hub. Any tips before I set about this. I'm happy enough with the Hope 'hit it with a mallet' style of bearing replacement but the DT website seems to indicate that I may need special tools 🙁
Posted : 19/07/2010 10:13 pm
You will need a ring drive removal tool.
Black tool at the bottom. Its £60 though.
Posted : 19/07/2010 10:22 pm
Blimey- is there a bodge available?
Posted : 19/07/2010 10:26 pm
Nope, and they are usually ferkin' tight those ring drives, nearly removed a vice from the bench getting one of those out.
Posted : 19/07/2010 10:28 pm
You wont do it without the removal tool for the inner cog.
I took mine to local lbs and used there tool. With the tool in a vice you fit wheel over it and unscrew. Sounds easy but when I say unscrew I mean spoke breaking pressure, as the cog had some locktite on mine. Also dont fit Superstar ceramic bearings as they are a tad wider than originals and the outer seal catches the cassette when fitted into dropouts.
Posted : 19/07/2010 10:30 pm
OK, LBS for me it is then. Ta guys
Posted : 19/07/2010 10:44 pm
