Bearing Removal - S...
[Closed] Bearing Removal - Surly Singlespeed Hub
Realised the bearings were shot last night so tried to remove them this morning by gently tapping them out with the axle.
Managed to destroy the bearings ๐Ÿ™ the outer face and balls came away but the shell is still stuck in the hub.
What's the best way to remove the shell? It's currently soaking in penetrating fluid, is it a matter of being patient and then carefully drifting out with a blunt object?
Posted : 23/05/2014 11:00 am
Can you get hold of a welding kit?
http://blog.hemmings.com/index.php/2009/03/04/a-neat-trick-for-removing-bearing-races/
Posted : 23/05/2014 11:39 am
If the outer race is now stuck In a hole where you can't get to the back of it then I often use a die grinder and cut a small slot into the race to remove the tension.
Works with a dremel style tool just be carful not to mark the alloy hub to much
Posted : 23/05/2014 11:56 am
Thanks - managed to lever it out eventually with a flat bladed screwdriver. Spoke to the LBS who recommended more brute force and ignorance which seemed to do the trick
Posted : 23/05/2014 12:11 pm
if you think you'll make a habit of it then a blind bearing puller might help;
Posted : 23/05/2014 12:15 pm
