Bearing removal, OM...
[Closed] Bearing removal, OMG, WT* etc etc
I'm trying to remove the cartridge bearings from my ( Hemlock ) rocker plates. Reccomended process of brute force involving chisels, screwdrivers and hammers, does not encourage the cases to budge. 👿
Any tips ?
Posted : 21/01/2009 2:50 pm
Not done a Cotic but on a mates Trek the other day we made a puller from some studding, nuts & a 21mm deep socket - If they're knackered you can damage them getting them out & then use them to push the new ones in.
Did you get my email address I sent you re the Verb trip?
Posted : 21/01/2009 2:56 pm
If all else fails you could try a LBS
Posted : 21/01/2009 2:58 pm
you have got the rocker arm sat on something solid haven't you? If the rocker arm is moving when you hit the bearing it will go nowhere. A puller using threaded bar and sockets/washers is the easiest way
Posted : 21/01/2009 2:59 pm
that would be a humiliating admission of defeat 🙁
true, but if its a case of a bit of pisstake at the LBS or shelling out £100 for new rocker arms, I know what I would do.
Posted : 21/01/2009 3:01 pm
And I know who his LBS mechanic is... I wouldn't... 😉
Posted : 21/01/2009 3:09 pm
 v10
You can usually make a little puller out of parts in your bits box.
20mm 1"1/8th headset spacer
Headset top cap
Long top cap bolt (usually get them with avid post mount brake bolts)
A bolt and a few washers for the bearing side.
oh and a 5mm allen key to turn it with 🙂
Posted : 21/01/2009 3:11 pm
I like v10's little puller, that's about the best bodge one I've read about.
Posted : 21/01/2009 3:17 pm
If all the bearings are shot just put your rocker arms in the oven set to 100c (lowest gas setting) and have your same kit (and a heatproof glove) handy when you get them out in 10 minutes.
(Assuming they're anodised and not painted, paint may be damaged).
Posted : 21/01/2009 3:35 pm
Thanks all. Salvation is about to arrive in the shape of a strong vice and two socket spanners, one to push, one on the other side to receive.
Mark, I will get around to sending you the Verbier details some time before the weekend.
Posted : 21/01/2009 3:58 pm
 Del
as above it does need to be on something pretty solid. as an example i couldn't knock out cart bearings from hubs on my garden bench, but i can on my work bench. a thick bit of flat wood, with a hole drilled in it, big enough to allow the bearing to pass would allow you to **** it pretty much anywhere, including the garden path if needs be.
failing that Jim will have a brass widget for doing it in a far more calm and relaxed manner, in fact the old bearing will probably make him a cup of tea after...
nowt that can't be fixed mate but i know how frustrating it can be. 🙂
good luck.
Posted : 21/01/2009 4:02 pm
I'm off to see the man right now. It's his vice/socket solution
Posted : 21/01/2009 4:07 pm
Socket set and a vice. Don't be shy with the mallet and WD40 though!
Posted : 21/01/2009 4:26 pm
If you use a socket make sure the new bearing will fit inside. A 12 point socket has more room than a 6 point one. Nothing worse than pushing the bearing onto rather than into a socket.
Posted : 21/01/2009 4:47 pm
