Bearing re-use.
[Closed] Bearing re-use.
Whilst poking round for something else I found the old bearings for the swinging arm of my 06 Enduro.I never throw bearings if they are not knackered as they often have a second life as something totally different. Thought they looked familiar then the penny dropped. They are the same as the poxy things in the original chain roller. Yeah, I now have 6 spares which is good as they seize in the first drop of rain. Tight I know, but these damn bearings only need to revolve not feel smooth so why spend money for nowt?
Posted : 17/05/2009 8:42 pm
Well, if they're knackered they'll sap energy even if they arent seized, but exactly - waste not want not.
Posted : 17/05/2009 9:51 pm
Pop the seals off 'em, clean & flush 'em through then repack them using Finish Line Ceramic Grease. It's amazing how much life that stuff can breathe back into old/part worn bearings.
Posted : 17/05/2009 10:53 pm
 RicB
I reuse bearings all the time, especially pivot bearings because they don't wear out.
I find it best to squirt in a few drops of chain lube once you've degreased them. Helps them roll much more smoothly. Thich grease doesn't provide much lubrication - more of a water repellant I think.
Posted : 18/05/2009 6:52 am
I use motorcycle chain lube a lot for this sort of thing as it "drys" well gooey
Posted : 18/05/2009 4:15 pm
