Bearing play in *ne...
[Closed] Bearing play in *new* forks
I have just got a set of 'new' (ie. unused) 2007 marzocchi xc700sl forks.
So far I'm quite impressed - need a bit of breaking in to loosen up the seals (much better after a couple of rides), but I'm enjoying the features + performance.
However, they have what seems to me to be quite a lot of play in the bushings, straight from the box.
I thought this was a bit odd (my previous 2 pairs of Marz forks didn't have any play) so I whipped the lowers off to have a look.
Everything looks fine, but the semi-bath oil that came out seemed quite dirty considering they had only had 2 or 3 hours of riding.
Is it possible that sitting around on the shelf for a couple of years has degraded the bushing surface somehow, such that they've worn very rapidly, or is noticeable play typical for '07 Marz forks/this model?
Posted : 15/07/2009 12:17 pm
apparently this is normal if you read the Marzocchi site. mine are the same - but need to go back because they've developed the TST wind-down fault.
Posted : 15/07/2009 12:27 pm
I thought that the 'deliberate play bushings' where introduced for 2008 though?
Posted : 15/07/2009 12:32 pm
I has a set of 08 MX comps, i could move them with my hands, in the end they replaced them and those i have don't knock. Won't be buying any more of those, Marzocchi forks. Going to way of another form manufacturer that starts with M.
Posted : 15/07/2009 12:50 pm
Mine had play in the bushings from new as well - it felt very odd at first but you don't notice it when riding.
They've proved faultless over 2 years use and the bushing play is no more than it was when new.
Posted : 15/07/2009 1:09 pm
Hmmm, well at least it's not just mine (same model/year muffin man?).
Will have to see how they go...
Posted : 15/07/2009 4:23 pm
[i]same model/year muffin man?[/]
Yep, these ones...
Posted : 15/07/2009 4:50 pm
