BB90 11 speed super...
[Closed] BB90 11 speed super compact road bike cranks; advice please
Desperately need lower gearing than the current 50/34 - 32/11 cassette (Shimano 105 shifters).
Top gear spin out is not an issue, but high cost is. Cannot stretch to new Middleburn prices but all suggestions and/or any "parts box bargains" would be much appreciated.
Sadly MTFU isn't an option - chronically poorly lungs and other long-term injuries.
Posted : 11/08/2016 1:09 pm
Spa cycles or sjsc will both have lower geared options based around touring cranks.
Will need a new bottom bracket, square taper, isis or octalink. So if you have a press fit frame you may have issues. If it's threaded it'll probably cost you ~100 (or less)
Posted : 11/08/2016 1:17 pm
Ah. Just noticed.
Bb90. You may be knackered. Unless you can sort a bb90 to bs adaptor.
Edit. Adaptor is impossible.
Posted : 11/08/2016 1:20 pm
Looked myself a few years ago - nothing apart from internal BB options. However, I have run a XT double MTB chainset on my CX bike- chainline was out a touch out so had to use a triple front mech - 24x36 chainrings were great for 'proper' offroading in the Highlands
Posted : 11/08/2016 1:24 pm
Get the road equivalent of a goat link and get an 11 speed mtb cassette. Plus a cassette spacer.
Posted : 11/08/2016 1:32 pm
I was going to suggest this
or this
So instead I'll say I'm using 11 speed shimano road shifters with a zee 10s mech to run an 11-36 cassette (1x10) quite happily. When that wears out I will be moving on to an 11-40.
Or use mtb cranks [i]and[/i] a wide range cassette!
Posted : 11/08/2016 1:48 pm
 jonk
SRAM 11-36 road cassette, if your mech is short cage then get a road link from 18 bikes.
Posted : 11/08/2016 2:48 pm
Enthusiasm now restored thanks all.
GM - yes Spa were my first port of call but as you suspected they've nothing hollowtech friendly. Will definitely give SJS a call.
Dbkr & Swny I do have a new Deore double that I'll try now - the 24mm spindle is approx 6mm longer though - can plastic crank spacers be used between the bearings and crank arms?
Posted : 11/08/2016 3:09 pm
Claris CX group set cranks and BB adaptor will sort the gearing.
Posted : 11/08/2016 4:24 pm
Not certain but I can't see why there would be any problems with that. Although if as I think you've got the trek only bb90 press fit setup then I'm honestly not sure!
Posted : 11/08/2016 4:34 pm
Oh, swanny, tell me more on that!
Any special cable routing? Presume it wasn't just a case of bolting the Zee mech on and bobs your uncle?
Posted : 11/08/2016 4:55 pm
Interested in this thread as could do with a lower gear for towing bike trailer (full of rapidly growing child and lots of stuff) on my escapade. Thinking of going to 105 hydro 11 spd for cable routing, hydro brake reasons mainly but wondered if could run an sram 11 spd 11-36 cassette?
Posted : 11/08/2016 9:45 pm
Apologies, somewhere in an edit of that description i lost the 'lindarets tanpan' bit....
I've got two- one making 10s shimano road shifters work with 10s mountain mech so i can run 40/28 x 11-36 on my roadrat for touring. The other is an 11s on the cross bike so i could fit 11speed shifters without needing a new rear hub for the 11s roadie cassette. Rs685 levers, tanpan, 10s zee and 11-36. I think the zee might even cope with an 11s cassette at a push.
Shifting is fine on both, the 10s one was very finnicky with initial setup, 11s wasn't (i did the 11s first).
Posted : 11/08/2016 10:51 pm
Can you get a bb90 triple chainset?
I run inner 2 rings on a triple. 42:30 nice and spiny. 8)
Posted : 11/08/2016 11:32 pm
thom thanks - sounds just the job as I definitely can't do "hurty" turning anymore.
I'll try a post on the WTD forum - is it a 130mm bcd triple I need?
I ordered a 38/24 double from Superstar for the Deore crank but I'm sure your solution with a bigger outer ring will play better with the braze on front mech's restricted lowest position.
Posted : 12/08/2016 11:53 am
I started a thread about the new FSA chainsets which are available with a 30/46 setup. Currently OEM on Willier cross bikes but hopefully soon to be available. Check my history as I'm too crap to post a link. Definitely hollow tech type but you may need an adapted for BB91.
Posted : 13/08/2016 9:27 am
