BB7 and machining q...
[Closed] BB7 and machining questions
9 Users
1. Do BB7 or 5 calipers mount straight on to post mounts (i/.e. without the washer set)?
2. Is anyone here up for turning a few small components from alu (dead simple job, I'd do it myself but no access to a lathe) EDIT for money of course
Posted : 09/01/2011 7:44 pm
1) no
2) not me, won't an adaptor do you?
[url= http://farm4.static.flickr.com/3418/3187666560_04dc336be0.jp g" target="_blank">http://farm4.static.flickr.com/3418/3187666560_04dc336be0.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/25655510@N02/3187666560/ ]090111 Sunday Mornings Ride & Run[/url] by [url= http://www.flickr.com/people/25655510@N02/ ]Johnclimber[/url], on Flickr
Posted : 09/01/2011 8:10 pm
yes - for a 160 front disc on a post mount fork IIRC
Posted : 09/01/2011 8:14 pm
Ah OK 50:50 so far 🙄 😀
JC I want to put my mounts on a frame (post rather than IS). See my "epoxy" thread.
EDIT and d'oh you're such a noob!
Posted : 09/01/2011 8:30 pm
Mine mounted straight onto mx pro post mount 160mm disc with usual avid washers
Posted : 09/01/2011 8:50 pm
Isn't the washer set required as part of the tri-align system?
Posted : 09/01/2011 8:57 pm
Hmmm 67:33 now and a query 😮
Posted : 09/01/2011 8:58 pm
Yes you will need the washer set but no adaptor for 160 front disc.
If you are putting rear mounts on yourself you can put them where you want surely. However if you epoxy them will you please3 video the first attempt at using them.
I think but am not sure that standard post mount rear would be a 140 disc
Posted : 09/01/2011 9:13 pm
Of course I can tj but I'd like it to be standard - not some shit bodge.
As for the video, if it doesn't work I'll fess up alright. May be a wait though, got to order the carbon fibre.
Posted : 09/01/2011 9:28 pm
You need the washer set up to fit straight to forks for a 160 disc on post mount without adaptor.
Posted : 10/01/2011 7:43 am
What exactly do you need machined? I like to know what i'm letting myself in for before volunteering for anything.
Posted : 10/01/2011 7:56 am
i just used a stack of washers off another set of BB7s, worked fine, no pics though sorry
Posted : 10/01/2011 8:01 am
coatesy: 12mm alu round bar tapped to M6, prob 6 off, need to work out length but prob 4cm or so.
Posted : 10/01/2011 9:36 am
Al where is your Epoxy thread, I wanted to take the mickey out of you but I can't find it?
Edit found it, and every one has done all the micturate removal already.
Posted : 10/01/2011 10:24 am
The answer is yes of course, but only if you design it correctly.
Posted : 10/01/2011 10:31 am
If a ride-able bike can be made at home from balsa wood and carbon fibre, I imagine some brake mounts can be safely added to a frame.
Of course the al-haterz seek to bully me for my free-thinking ways 🙄
Posted : 10/01/2011 10:37 am
make some sketches, I'll do some calcs.
Posted : 10/01/2011 10:40 am
CBA with calcs, though I may need to think about bracing if I do this on forks.
Posted : 10/01/2011 10:42 am
Well a few simple sketches could well inform you of the bestest way to do this, but if you CBA then I shall leave you to your detractors then.
Posted : 10/01/2011 10:44 am
Turning the bar shouldn't be a problem, not sure if i've got a tap long enough to go all the way through, but could tap both ends if that's any use.
Posted : 10/01/2011 7:19 pm
Have you tried your local fasteners to get some suitable shim/hollow rod and then just run a tap down it.
BB-7 callipers bolt straight onto a post-mount for 160mm rotors (on the fork). If the frame or fork has an IS mount then you'll need an adaptor.
Posted : 10/01/2011 8:11 pm
