BB cups entirely lo...
[Closed] BB cups entirely loose in BB shell
[#612022]
Checking over my road bike a few days ago i found the BB cup loose on the drive side. I took off the crank to remove the BB but could neither loosen nor tighten the BB cup. I figure that the thread is completely knackered. It's an aluminium frame. I've heard the BB shell can be reamed and re-threaded (or re-tapped).
Are these satisfactory solutions or is the frame irrepairably damaged?
Any advice. Also, to ream it, how much should i expect it to cost?
thanks
Posted : 07/06/2009 3:42 pm
I think ive heard of Argos cycles doing this - just checked online and yes..
http://argoscycles.com/www/renovation-pricelist.htm
"Ream and sleeve bottom bracket (thread replacement both sides) £65.00"
Posted : 07/06/2009 3:58 pm
I'm sure BETD do similar. Bore it out and bond a steel insert in there. Not seen it done but it's sound principles from a engineering point of view.
Posted : 07/06/2009 4:29 pm
[url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=236&Name=Frame+repairs ]BETD frame repairs, £50[/url]
Hope this helps...
Posted : 07/06/2009 5:45 pm
