Barfly 4.0 with Ren...
[Closed] Barfly 4.0 with Renthal Apex & Garmin 1030
Anyone tried this?? Struggling for mounting options with 35mm bars, the top cap mount doesn’t work as the garmin won’t clear the stem.
Thanks!
Posted : 25/03/2021 10:13 pm
 StuE
Not tried the barfly but this works
https://www.76projects.com/shop/adjustable-garmin-mount-p35eg
Posted : 27/03/2021 1:21 pm
I use a Barfly mount for 35mm bars with a Garmin 800 and DMR defy stem which is a similar design.
Works fine.
I also use a stem mount on another bike with the same stem. You just need to put a spacer under the stem mount to lift it up high enough to clear the Garmin.
Posted : 27/03/2021 1:32 pm
