Avid juicy rotor up...
[Closed] Avid juicy rotor upgrade ? 185-203 same mount ?
[#2804735]
Hi all,
With the new 20mm through axle wheel coming i may as well go to a 203 Front Rotor.
Can anyone advise if my current mount which is for a 185mm rotor will fit ?
Or will i need a different caliper mount ?
I currently have Custom Avid Ultimate 7 hydraulic disc brake with 185mm rotor.
Thanks
Paul
Posted : 30/05/2011 11:07 pm
Different mount for sure.
Also, have you changed forks?
Do the new forks have a different mount type to the old ones?
i.e. IS mount to Post mount.
Posted : 30/05/2011 11:15 pm
Hi
Im upgrading from a 2008 Fox Float 32 to a set of 150mm RS Team revelations so im really not sure.???
Any ideas thanks
its ridiculous the amount of non-standard stuff we have to deal with 🙁
Posted : 30/05/2011 11:22 pm
New forks will be post mount.
This one...
http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=13718
I've got an Avid G3 rotor you can have for £13 posted. Tis excellent condition, but if not happy in any way would refund anyway.
Shameless oportunism I know, but you did ask. 🙂
Posted : 30/05/2011 11:23 pm
Not sure what standard the 2008 Fox forks were.
If the mounts are about 3" apart & bolts go front to back then that's post mount. 2" apart and left to right is IS.
Irellevant though. You need an adaptor to take your front caliper (whatever standard that is) up to 203mm post mount.
If your front caliper is post mount then takisawa2's linky is good.
Posted : 30/05/2011 11:55 pm
whats wrong with the 185 disk?
Posted : 31/05/2011 12:31 am
 cp
08 fox have post mount. As above, you'll need a different mount for the larger disc.
Posted : 31/05/2011 7:19 am
