avid juicy 3. braki...
[Closed] avid juicy 3. braking power disappears in cold weather.
 Pook
last night riding in -3, my front brake just went - it had no power at all, and the lever pulled all the way to the bars.
is it air in the system contracting?
how easy is a juicy 3 bleed?
Posted : 01/02/2012 8:49 am
Check for blown seal if it went suddenly - juicys not easy to bleed IMO
Posted : 01/02/2012 8:52 am
 Pook
sorry...just to clarify; its done it before and recovers.
Posted : 01/02/2012 9:03 am
still sounds like a seal - loosing its "sealability" in cold weather -- maybe in the master cylinder so no leaks
Posted : 01/02/2012 9:32 am
 Pook
Bugger. Warranty replacement job then?
Posted : 01/02/2012 10:19 am
pook, are you ooop north? if so this explains it, grimness leads to seal failure.
Posted : 01/02/2012 10:20 am
mine did the same thing the other day while moving the bikes around, went out and checked an hour later and all was fine,
Posted : 01/02/2012 10:36 am
if they're vaguely similar, the bleed on my juicy ultimates is easy.
Posted : 01/02/2012 10:41 am
Juicy 3's are easy to bleed, but it is incredibly messy and the dot fluid is nasty. My Juicy brakes are the worst I've ever owned as they never seem to bite correctly
Posted : 01/02/2012 12:21 pm
the first part is wrong the second part is correct ....
wear gloves yes as it is a fluid you dont want high exposure too but its not "nasty" unless you abuse it .... but the avid bleed method is one of the cleanest around - with a good quality kit !
Posted : 01/02/2012 12:48 pm
agreed, bleeding avids is easier and tidier than shimanos.
Posted : 01/02/2012 12:52 pm
