anyone know where i can get one? :/
They come with the official Elixir pads, not cheap but easiest way to get them.
Split pin?
I droped mine on the grass yesterday. Found it after some frantic searching otherwise i would be asking the same question.
Questions like these make me glad I pay a guy to fettle for me.
bigyinn - unfortunately not. Its a bolt that runs through the caliper, through the pads then through the opposite side of the caliper. Thes a small c clip also. Had a small tumble at Glentres, lost the c clip and the bolt in turn worked its way loose....
Same sort of setup as my M595s then! Except this uses a split pin to keep them there as std. Should work the same for yours too.
I have lost the C clip on my back caliper. Mental note, tighten the bolt tonight.
evening bunch??
Buy a set of elixir pads, use the bolt/c-clip and save the pads until you need them
will check the spares drawers tomorrow, may have something of use.
I cant find any pads that seem to come with the bolt and c clip. only the spring...
I replaced both of mine with split pins to save the hassle of trying to extract a stupidly small allen bolt when standing by a muddy trail in pouring rain as happened to me last year.
Split pins (from Shimano M575 brakes) work absolutely fine.
Got some from [url= http://www.bikechase.co.uk/index.php?p=199537 ]here[/url]. Cost £6 for 2 though.
