Automotive tyre sea...
Automotive tyre sealant in tubeless bike set up
Have one of those puncture repair kits left over after buying a spare wheel for my car. Would the sealant work in a tubeless mtb wheel? No biggy if not. Just like using stuff up.
Posted : 11/08/2024 9:56 pm
Don’t they tend to contain ammonia or some other substance that tends to wreck tyres?  They’re only meant as a quick fix to get you home/to the tyre shop.
Posted : 11/08/2024 11:34 pm
I used to use green tractor tyre sealant when I had ghetto tubeless. It worked and was cheap. Prob just stick with the proper stuff now tho.
Posted : 12/08/2024 6:33 am
I use Holt's TyreWeld along with liquid latex for ghetto tubeless (i.e. with a split inner tube as a rim strip). Works fine, never had a problem. When I first started doing ghetto tubeless 20 or more years ago, I used Slime and TyreWeld. The Slime is longer lasting, the TyreWeld seals them up fast.
Posted : 12/08/2024 7:23 am
Oko fluid from a farm shop or Amazon.
Water it down 25%
It works very well and doesn't dry out like latex based fluid.
Posted : 12/08/2024 9:10 am
Don't worry about the ammonia angle, Stans and the like has ammonia in it to keep the liquid latex - er - liquid in the tyre.
Don't sniff the good stuff though, FYI yes it does smell stronger than household ammonia. #understatement
Posted : 12/08/2024 9:39 am
