I can get some new 520's for £12, XT pedals for £48 or XTR for £78.
I ride with DX647 usually but have built up a 2010 P7 HT to compliment my burly built LTC - normally i wouldn't care about weight but i've built the P7 with full XTR!
Should I splash the cash or stick with the trusty 520's??
Real world experiences/comparisons please
£12 where from
We have 520s, 540s and XTs on three different bikes.
The 540s/XTs are easier to fit than 520s and they get lighter as they get more pricey but in function, there is very little difference.
I went for XTs over XTRs because the black of the XTs matched my Stumpjumper... 😳
In what way are the 540s easier to fit?
£12 where from
Ill tell you in a min - once i've decided what to do 😀
520 any day.
520 i really don`t care about what happens at that price.I just buy another pair.Com on spill the info i need some new ones 😆
Can use a large allen key as well as a pedal spanner (I think)
[i]In what way are the 540s easier to fit? [/i]
Allen key from the back of the crank arm rather than trad. pedal spanner. It's a slight advantage i guess, if you care about these things...
540s are significantly lighter than 520s, XTs aren't much different to 540s, XTRs are a bit lighter again, although still significantly heavier than equivalent offerings from Look, Crank Bros etc.
For £12 it'd be 520s no doubt!
Buy Time instead.
520's here as well - can't see the point of the more expensive ones 'cause the 520's are excellent.
I could do with a spare set though, so where are these £12 ones!
ahh time with the clips made of monkey metal i was a fan until the metal bar just snapped as the bar was hollow it was clearly a manufacturing fault.
520's have allen key at the rear as well
so no difference in installation terms
Here you go peeps - only 5 more available - free P&P too (actually £13) and come without cleats.....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280518956730
Cleats are £5 from the same seller too..
No cleats with those though, hence the cheap price.
Crc £20 including cleats which is more of a bargin I reckon
520s all the way for me.
guess that depends if you need cleats or not really?
if for a 2nd or commuter bike etc and you already have cleats on your shoes....
Absolute Cycles ebay shop, used them loads of times, really quick service and often have alot of good bargains (they prob have cleats on there for less than £7 too if you look at the other listings)
tks.
ordered - thanks
Cleats wear out and they're not cheap though clearly if you don't rode much... 😉
That's what I thought - but couldn't be bothered going out to the shed to check. I have 520s on 3 bikes and they just go on forever. Am thinking of getting Wellgo lightweight ones for the race bike though just to lose some weight.
I have 520's on one bike and XT's on the other, wish I had 520's on both and put the extra cash towards a Hope BB!!
I don't need the cleats as these will be replacing 505's currently fitted on a couple of my bikes, so bought the two remaining Ebay sets. Thanks for the pointer!
No probs - lets hope that they have 6 sets in stock!!
have both 520s and XTR.
The 520s feel more solid.
I've used 520s, 540, and XTR but I now run the Bikehut spds which are lighter than the lot (300g vs 325g for XTR) and just as good.
Of the Shimanos the 520 wear their bearings faster than the others.
These ones Reggie?
Thats what I like about this forum, all of a sudden someone comes up with a bit of kit thats just got WIN written all over it, if these last like a 520, within a fiver of the price, and lighter than XTR.
I got some near dead 959 (XTR before they did XTR pedals), will have a look at Halfords.
520 don't have sealed bearings. Mine wore out in under a year. I have some 540 which I've been using for 2 years without servicing them and they've been faultless. I think these have sealed bearings.
Matt
I service my 520s about once every two years and they seem fine.
the bikehut ones I use are the same as the Powerplay Force. They are good to use, robust, reliable and light. I've run them all through winter and they isn't a sniff of play in the bearings.
The latest Bikehut ones in Halfords are very slightly different but basically the same.
My XTs (one of them) needed greasing a week after I got them - one started to click a bit.
Since then they've been faultless.
My wife's bike has the 540s - again faultless.
Got 520s on the road bike (it's our "cheap" bike!) and they are fine too - it's still flipping like (to me) even with them on!
From experience the M540s are indentical to the XTs other than colours.
M520s have pretty much the same bearings as M540s / XTs.
I can only surmise that M540s / XTs are lighter as the pedal body is slightly shorter and has an aluminium bearing collar rather than plastic.
I've used all 3 types and tbh i cant tell between them in use.
those powerplay/halfords ones will be made by wellgo or VP so have a hunt around for best price/brand/colour: they look excellent but I've not been keen on the split bar type clips over the single Shimano style.
520s have a 6mm allen key slot in the back, and spanner flats. If it's been fitted with a pedal spanner you will likely break your allen keys before they come off! 6mm allen keys are generally relatively short.
540s have lighter axles just with an 8mm allen key in the back, no spanner flats.
If that matters!
the bikehut ones aren't split bar and they are as clicky/slick as 540s.
They come up on ebay periodically and go for about £15, which is a steal IMO. Lighter than XTR and as good as 540s in use. Bargain.
Aren't 540's sealed bearings? 32 from merlin less than half rrp and feel quite a bit lighter than 520's which I have also found unreliable.
For £32, I'd get 540s, that's a steal.
When the retail prices were £30 and £40 for 520s and 540s the 540s were well worth it, now the 540s are meant to be about £65 they're not so good!
Halfords have buy 1 get 1 half price on cycle accessories.
So you get 2 pairs (incl cleats) for £37.50.
Hmmmm, those or a pair of 540s. Can't decide!
