Are there any clutc...
[Closed] Are there any clutch mechs that will work with a 9 speed x9 shifter?
[#8474494]
Morning all,
Can anyone tell me what clutch mechs (if any) that I can run with an old 9 speed sram x9 shifter?
Posted : 28/04/2017 11:39 am
I fear you may be out of luck. Iirc clutch mechs came in with all the 10s systems
Posted : 28/04/2017 11:56 am
[url= http://singletrackworld.com/forum/topic/9-speed-sram-shifter-with-a-shimano-10-speed-clutch-rear-mech-will-it-work ]Supposedly[/url], it works with a Shimano 10spd derailleur after a bit of fabricobbling.
Posted : 28/04/2017 12:02 pm
^ as above, use 10 speed Shimano with a spacer at the cable mount, works great althogh may require a bit of trial and error to get the spacer size just right.
Posted : 28/04/2017 12:46 pm
I've got a wee spacer I machined for it, <somewhere>, that'll adapt a shimano one to work. Drop me an email at andrew@blackjack.f9.co.uk and then nag me every couple of days and I'll have a look and quite possibly even find it.
It's basically 6mm of spacer- you can do it with washers and a long bolt but this just finesses it and makes it work that much nicer. I found it works basically like stock.
It's not that exciting a different either, to be fair, if you want chain retention it's a wee bonus but not massive, it's narrow/wide rings that make that work properly... But it controls it a bit better for multi rings, and cuts noise and slap right down, that's nice.
Posted : 28/04/2017 12:52 pm
Yes, you will need a spacer on the mech cable clamp as others have explained.
I am running a (10sp) short cage shadow+ mech on an 8 speed drivetrain with Sram X4 shifters. It works brilliantly, the narrow wide ring helped but the clutch mech is what keeps the chain on during rocky descents.
Posted : 28/04/2017 2:00 pm
 Del
I ran a sram mech 1x9 without any problems for a while. sram mechs always had stronger springs.
Posted : 28/04/2017 3:22 pm
ballsofcottonwool - Member
I don't think that's true tbh (source: broke the clutch mech in one of my mechs while in the alps and took it out, chain stayed on. Built an XC bike with a clutch mech and a narrow wide and a top-only chain guide, chain fell off
Posted : 28/04/2017 3:40 pm
Cheers for the info folks. I've basically built up a cheap hack from spares (Nice frame that I had welded up) and did a bodged 1x conversion and the chain won't stay on on bumpy ground.
I ordered a NW superstar chainring in the sale at the minute and the rear mech I'm using has seen better days so I thought I'll try and get something on there with a clutch anyway.
Andrew, I've emailed you about the spacer.
Does anyone know, will an slx one work also?
Posted : 28/04/2017 3:44 pm
Yep, all the 10 speed shimanos are basically the same from that point of view
Posted : 28/04/2017 3:52 pm
Del - Member
ditto.
I've used X9 & X0 in 1x9 set ups without a guide.
One used a NW ring the other a STD Hope SS find and I can't recall ever dropping the chain.
Both springs seem far stronger than the SLX mechs I have and lighter too!
Posted : 28/04/2017 4:45 pm
