Are maxxis single p...
[Closed] Are maxxis single ply tyres ok to use with a 'ghetto tubeless' set up?
I ask cause i brought them by mistake, i meant to get the tubeless version ๐Ÿ™
Posted : 23/06/2009 7:01 pm
I've used plenty of single ply wire bead Maxxis ghetto stylee and they are great.
Posted : 23/06/2009 7:04 pm
cool, they are the wire bead version...
i think i'll give it a go then.
Posted : 23/06/2009 7:05 pm
used both wire and kevlar beads. high rollers, swampthings and crossmarks. All single ply and all work well
If they are wire, put them on and use a tube to inflate them for a day or so first. It helps put the shape in them and makes them easier to seal.
Posted : 23/06/2009 7:20 pm
I've used both SP and DP with stans no tubes. The SP wore out in 4 months being run at about 25psi. Never punctured until the sidewalls wore out from the flexing in gritty conditions. The dual plys work better, but obviously weigh a lot more. sealant required for both.
Posted : 23/06/2009 10:41 pm
