Are Deore (M615) br...
[Closed] Are Deore (M615) brakes 160mm as standard (or 180mm)
Trying to help a friend order brakes for his bike.
Do the brakes use a 160mm or 180mm disc at the front (by default)?
He's a bigger guy so suggested he use a 200 mm disc. I don't know if he'll need a +20 or +40 mm though.
These are the brakes I've recommended.
http://www.aliexpress.com/item/DEORE-BR-M615-BL-M615-Hydraulic-Disc-Brake-G3-HS1-RT54-rotor-MTB-bike-brake-for/32314744843.html
Thanks all
Posted : 29/04/2015 5:45 am
 cp
They are powerful, doubt you'll need to go bigger than 180 unless he's very big and rides alpine descents all day long.
Posted : 29/04/2015 6:25 am
He's big!
130kg+ , I'd guess.
So, ignoring your advice ( 🙂 ), he'll need a +40mm adapter for 200mm? 180mm would be fine for him, but he's used my 200mm and is keen.
Thanks for the reply.
Posted : 29/04/2015 7:31 am
I'm 10 stone,I use 180mm on front and TBH I could probably do with 180 on the back as I'm only using 160 at the mo,really good brakes,I've had mine a year now and still sharp,best he go 200 to be sure,won't do any worse will it.
Posted : 29/04/2015 8:16 am
75kg with kit 180 front 160 rear. When it is steep and wet I want more. Zee next tim. 130kg I would want zee....
http://www.bike-discount.de/en/buy/shimano-zee-disc-brake-br-m640-b-set-86999?currency=3&delivery_country=190
Posted : 29/04/2015 8:22 am
Are you on Zee frosty,iff so what are they like?
Posted : 29/04/2015 8:45 am
I'm 90kg and ride uplift days on a HT. 180 rotors F&R with Uberbike's Race Matrix pads is an awesome combination.
Posted : 29/04/2015 8:52 am
Aliexpress, really? I'd go for SLX with the ceramic pistons, £86 from Ribble last time I looked, exc rotors of course.
Posted : 29/04/2015 9:36 am
Apparently he's 115kg... guess he must have been wearing unflattering clothes (he is a maths teacher!).
Although he enjoys riding, I don't think he'll splash the cash on Zee. 200mm and Deore / SLX seems to be a better idea.
Thanks for the replies
Posted : 29/04/2015 10:02 am
