I currently have some old (2007) shimano hone combined shifter/brake levers. Can I swap the levers for some normal shimano shifters?
The reason for this is I want to go 1x9, and just use a single right hand shifter pod.
Posted : 13/09/2012 9:03 pm
Yep.
Posted : 13/09/2012 9:06 pm
As long as you have the correct hoses / connectors then yes you can mix and match.
Posted : 13/09/2012 9:09 pm
newer hose is different to older hose though, I am told.
Posted : 13/09/2012 9:11 pm
It all uses mineral oil, no? So it will be fine, if you can make it fit OK. I have an XT lever mated to a Magura caliper. Works fine.
Posted : 13/09/2012 9:20 pm
The inner bore of the new hoses is different to the older ones, so good luck bolting a new component on one end, and an older one on the other.... Deore level and down are OK IIRC.
Posted : 13/09/2012 9:40 pm
