Anywhere got pugsle...
[Closed] Anywhere got pugsley's in stock?
Looking for complete bike 18" or 20"
Posted : 27/05/2011 9:46 am
Tried the Bike Chain, Edinburgh?
Posted : 27/05/2011 9:48 am
they only have a 16" in stock, pity
Posted : 27/05/2011 10:02 am
Speak to them long enough and they'll convince you it's perfectly sized, Sir!
Posted : 27/05/2011 10:14 am
With a large enough discount it might 😆
Posted : 27/05/2011 10:23 am
try Brixton cycles.
had one hanging off the ceiling recently
Posted : 27/05/2011 10:35 am
Alf Jones in Wrexham.
Posted : 27/05/2011 10:38 am
A quick Google threw up this...
http://activesport.co.uk/shop/article_292.5SUPU18W/Surly-Pugsley-26%22-Adveture-Bike.html?pse=coa
Posted : 27/05/2011 10:42 am
waiting for a mail back from them.
Most the ones online are not due in till late july, which isn't long to wait anyway.
Posted : 27/05/2011 10:47 am
i know its not a pug but im gonna post it anyway 😉
Posted : 27/05/2011 10:51 am
You posting that to me Terry? 😉
Posted : 27/05/2011 10:54 am
Those 100mm rims TR? What pressure you running?
I am thinking of tubeless but I wonder how low one can go (running 80/50mm rims).
Posted : 27/05/2011 11:02 am
they are 100mm rims ... had them down to 6 psi ....
rode them at about 12 at 10 under the ben
once you pump them up to 30psi they are no draggier than a standard MTB - but not as much cope in the mud or the downhills.
I want to build a lighter set of wheels on flat tops or surly rollin daryls. I also want to put gears on it 1/9 with a 28 at the front (currently 34:22 and rode all but the final kick on the climb off puggy line at 10 under) - bike as you see it there is about 34lbs (bruneeps face was a picture when he picked it up) shaggy has one that he has at 27lbs ... given my wheel set alone weighs 12 lbs - most of which is in the rims ! - its plausable
then it will be fine for touring anywhere id take a standard mtb with the bonus of being able to **** off onto the soft stuff ... think the other edinburgh AL is thinking along the same lines.
Posted : 27/05/2011 11:07 am
al kelly?
My thoughts...I hate the rolling you get at low pressures so tend to run 12+psi, going tubeless would save 500gm a wheel, would make it OK to use 50mm rims @ 800gm which couold be drilled to 600gm.
Then you're only (200 + 600)gm over a lightish xc-wheel set up.
Hoping to create a FS fat bike but the frame is 8lb 🙁 will be a PITA after the 9zero7.
Posted : 27/05/2011 11:12 am
wont it be prone to burping at low PSI- surly tires are slacker than a slack thing in slack town .... like shaking a sausage in an alley if you will !
Posted : 27/05/2011 11:39 am
Indeed, but I'd like to try it, not really looked into it but am aware there's alot of chat on mtbr.
epicyclo has some cool ideas too.
Posted : 27/05/2011 11:42 am
Brixton not got any either.
See what turns up from Alf Jones......
Posted : 27/05/2011 12:55 pm
Nothing to add to this really but if TR can just post a pic of his fatbike for the sake of it so can i. 😀
[url= http://farm5.static.flickr.com/4089/5395483739_76c9af3c7c_z.jp g" target="_blank">http://farm5.static.flickr.com/4089/5395483739_76c9af3c7c_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stu-b/5395483739/ ]hanging around[/url] by [url= http://www.flickr.com/people/stu-b/ ]singlespeedstu[/url], on Flickr
Posted : 27/05/2011 1:20 pm
You can only post pics if your willing to sell them to me ! 😆
Posted : 27/05/2011 1:22 pm
FFS, Really wanting a 20", but looks like it will be sept before they arrive.
Possible to build a custom bike for £1350 deliverd??
Posted : 27/05/2011 8:30 pm
Doesn't Charlie The Bikemonger have one in stock for test rides?
Posted : 27/05/2011 9:28 pm
I think Keep Pedalling in Manchester might do.
Posted : 27/05/2011 10:02 pm
Sent both a mail, thanks for the pointers
I'm just over 6" with a long torso, on paper i think that the 18" might be ok as the effective TT is the same as my 18" blue pig??
Will the 18" be ok, or should I wait to find a 20"
Posted : 28/05/2011 7:44 am
I looked at one at a leggy 6' 0.5" and would not have got a 18", I don't like a wee bike though.
You could build one up w/SH (non-fat specific) parts for that I reckon...cranks/bb, rims and tyres are the pricy bits, everything else is std.
I built a 9zero7 up for <£1K (frame cost £300) with only a few bits having come from my cupboard
Posted : 28/05/2011 8:00 am
My sand man wAs < 1k too but i bought frame forms rims and tires second hand but un used !
Posted : 28/05/2011 10:26 am
Try Zaynan @ Practical Cycles maybe - [url= http://www.practicalcycles.com/userimages/procart82.htm ]here[/url]
Posted : 28/05/2011 10:39 am
If SSS can most his then i may as well... 🙂
down in weight to a xc whippet 35 lbs with mechs back on after drowning the alfine in the sea 😳
[url= http://farm3.static.flickr.com/2728/5762068422_69249c4a7d_b.jp g" target="_blank">http://farm3.static.flickr.com/2728/5762068422_69249c4a7d_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/coastkid71/5762068422/ ]Peffersands[/url] by [url= http://www.flickr.com/people/coastkid71/ ]coastkid71[/url], on Flickr
Posted : 28/05/2011 10:47 am
yeah hub gears aint very water proof when your spinning them 🙁 - static they are ok lol
Posted : 28/05/2011 11:08 am
Coastkid - you are to blame for this whole situation in the first place, your 9 min edit is what set the whole ball rolling 😈 Awesome!!
I will be riding almost identical conditions to you on the moray coast. After you experiences with the alfine, would you say it was bad luck or just not fit for beach riding?
Enjoyed you dune riding vid last night!
Posted : 28/05/2011 12:54 pm
Slightly OT, seems like this is going to be months to complete whatever happens, so I was thinking of a semi fat option for my blue pig to serve beach duties through the summer.
Was thinking of 2.4 advantage or rear & 3" Duro Leopard.
Will this be ok for general beach riding on firmer sand?
Posted : 28/05/2011 1:06 pm
