After asking about pressing headset cups together or singly, the concensus seems to be for pressing one cup at a time (a video on the Cane Creek site starts with the lower cup). I've a relatively cheap Cyclus headset press and wondering whether there was particular process for pressing cups singly (I did them together last time). Pressumably I need to remove the cup adapters, the press as bearings between two washers, do I just rest these on the top of the headtube to press the lower cup?
If you have a press why not do them together?
I've come across different views regarding pressing headset cups, singly or together. I did them together last time and everything went fine but [url= http://www.canecreek.com/tech-headsets?view=video ]Cane Creek has an online video[/url] showing the installation of a headset with a press and recommend doing the cups singly, starting with the lower cup (otherwise I'd probably have stuck with pressing them together). [url= http://www.singletrackworld.com/forum/topic/pressing-headset-cups-both-together-or-one-at-a-time ]I asked on here[/url] and the concensus seemed to be for pressing the cups singely.
Ah OK I assumed you would need to do them together using a press, or singly with a block of wood!
