Anyone used one of ...
[Closed] Anyone used one of these crown-race removers?
[#2281876]
Anyone used one of these?
http://cgi.ebay.co.uk/Icetoolz-Crown-Race-Remover-E253-/160499637538?pt=UK_Spots_Leisure_Cycling_Tools_RepairKits&hash=item255e861d22
Does it take the crown off ok without scratching the crown?
Posted : 13/12/2010 10:16 pm
£20!
Screwdriver and a hammer. Bish Bosh job done.
Posted : 13/12/2010 10:19 pm
Yes it works neatly.
Posted : 13/12/2010 10:22 pm
my mate crushed part of his steel rigid fork with one.
he refuses to use presta valves as they 'snap off' though!
Posted : 13/12/2010 10:24 pm
thomthumb - Member
my mate crushed part of his steel rigid fork with one...
Then he was using it wrongly. You're not supposed to keep winding it in.
The idea is you wind it in a bit with the flat side up. Then you turn the fork upside down and give the edge of the tool a firm tap with a mallet. The crown race will come off quite easily. No great force is needed and no damage is done to the fork.
Posted : 13/12/2010 10:31 pm
Yep, got one used it and it works. Easier than blindly smashing away with a hammer and screwdriver
Posted : 13/12/2010 10:41 pm
Hammer and screwdriver or stanley blade if tight - spend £20 in the pub.
Posted : 13/12/2010 10:51 pm
I have one.Works fine
Posted : 13/12/2010 11:02 pm
why flat side up ? Doesn't that put force through a small area on the crown rather than the race ?
Posted : 13/12/2010 11:09 pm
scaredypants - Member
You're not trying to put force on anything.
You're simply closing down the diameter of the tool so it is smaller than the crown race. Then when you tap it, the tool can't come loose and the impact is transmitted to the crown race which pops off easily.
As for the screwdriver and chisel mob, I would never buy a used fork that had those sorts of marks on it. There's bodging and there's butchery 🙂
Posted : 13/12/2010 11:37 pm
Thanks chaps. Would usually use a hammer but not on some very expensive white forks I now have!
Posted : 13/12/2010 11:39 pm
[i]As for the screwdriver and chisel mob, I would never buy a used fork that had those sorts of marks on it.[/i]
The artistes among us can use the hammer and chisel in a way that leaves no marks....
Posted : 13/12/2010 11:41 pm
OK, I'm imagining oldgit who posted here about a wc sid carbon-crowned racy fork with a race "stuck" on.
Closing the tool to a smaller diameter and pushing the race off MUST be imparting a force (minimal impact, but still force). If you have the angled edge down, it's only applying that force at a tiny area of the crown, at its outer edge (where it just might not be so robust anyway ?).
If you did it with the flat side down and the angle up, there'd be at least as big an area of crown taking the force and more likely a larger area as the flat suface slides under the race and along the flat crown
makes more sense to me
Posted : 13/12/2010 11:56 pm
crikey - Member
Then you are truly artistes 🙂
Sadly most people aren't...
...If you did it with the flat side down and the angle up, there'd be at least as big an area of crown taking the force and more likely a larger area as the flat suface slides under the race and along the flat crown
Agree, it seems to make more sense, but I have found the other way less likely to scratch or leave a mark.
BTW you're not using the tool to push anything if you can help it*. You are just making it a smaller diameter than the crown race so it doesn't slip off when you tap it.
*sometimes there is so little clearance that you have to clamp it a bit tighter.
Posted : 14/12/2010 12:11 am
Stanley blade method here. Hammer one in one side, one in the other. Two in the first side, two in the other. Repeat for 5 mins max and the crown race is freed with minimum heavy artillery.
Posted : 14/12/2010 12:46 am
spindi - Member
Stanley blade method here...
I would only do that on a steel steerer tube.
If you nick an alloy steerer tube doing that.... 🙁
Posted : 14/12/2010 11:16 am
I use one, as said above, don't over-tighten it and then turn the forks upside down and give it a tap, works a treat with no marks at all,
£700 forks and then bash em with a hammer and screwdriver,Seems silly when the tool is cheap
Posted : 14/12/2010 11:33 am
lasted about six forks in the workshop here. The sharp edges fold over when the tool is tapped down to move the crown race. ok for home use.
Posted : 14/12/2010 11:56 am
Yours must have been made of cheese.
Posted : 14/12/2010 12:06 pm
works very well, i have a 'car' version, as stated tighten a tiny bit ,tap edge of tool, tighten a bit more ,tap, then before you know it off pops the crown race easy peasy.
Posted : 14/12/2010 1:33 pm
I've just splashed a bit of cash on specialist tools for just this sort of job
I've bought a bigger hammer 🙂
Posted : 14/12/2010 2:39 pm
