PSA New Edge 705 fi...
[Closed] PSA New Edge 705 firmware update (V 3.3)
[#2281903]
As title, lets see if people have as much trouble with this as they did with V3.2 🙄
Posted : 13/12/2010 10:29 pm
I'll be waiting on some user feedback before making that mistake again!
Posted : 13/12/2010 10:38 pm
Already updated here, but then again I never had a problem with V3.2, looks like I'll be going out for a ride in the cold tomorrow.
Posted : 13/12/2010 10:58 pm
Notes:
IMPORTANT: UPGRADING TO VERSION 3.30 WILL CLEAR ALL USER DATA.
Change History
Changes made from version 3.10 to 3.30:
Improved calculation and reporting of total ascent, total descent, and grade.
Correctly calibrate wheel size when using PowerTap hub.
Backlight setting saved and set automatically on power-on.
Improved 'Go Home' functionality to search for any user-created waypoints named 'home'.
Added new timezone for Santiago, Chile.
Allow house number 0 on find address page.
Reduction in speed spikes from sensors.
Added message indicating elevation calibration point (Save Location) has been found.
Improved robustness of internal filesystem.
Changed XML settings file for use with Garmin Training Center.
Improved autopause detection.
Improved SD card reading.
Improved reliability of barometer calibration.
Improved reporting of elevation data.
Translation updates.
Posted : 13/12/2010 10:59 pm
From memory, that's everything that was in 3.2.
Posted : 13/12/2010 11:27 pm
I don't think that was there before, anyway I tried V3.3 out on the Quantocks this morning and I've nothing to report.
Posted : 14/12/2010 4:48 pm
Never quite sure how it does the wheel size calculation with a Power Tap, guess that only works if you're outside. Equally ive yet to work out how the PowerTap manages to do speed when on the turbo. Think I'll wait and see before I upgrade!
Posted : 14/12/2010 5:44 pm
Since my last upgrade the time paused function no longer works on total time out
As i spend a lot of time stopped i quite like the function 🙂
Posted : 14/12/2010 11:48 pm
