Anyone tried making...
[Closed] Anyone tried making their own steel frame?
Hello,
Anyone tried to make their own bike frame? I really want to make my own steel 29er frame. I have a lathe, milling machine, MIG welder, and a load of basic tools, and know how to use Autodesk Inventor.
Is this a bad idea? What are the pitfalls? It cant be that hard..... right?
Any helpful links? I keep finding links for homemade carbon frames, not much on steel ones...
Chunky
Posted : 31/12/2013 10:36 pm
 Olly
Ive not done it, but lets be honest. There isnt THAT much to it. (im sure it takes a lot of skill to make a really nice fraqme) Welding thin Reynolds you will have to be super careful not to blow through the tube, but i reckon if you stick with on-one grade steel you'll be reet!
Get a big sheet of nice thick Ply to build your Jig off and give it a go.
measure twice, cut once etc etc
Worst case scenario it snaps on you, meh.
your first will be a bit shonky, and maybe wonkey but whats the harm in trying?
Check this out:
Posted : 31/12/2013 11:54 pm
MTBR framebuiding forum is your friend. Read everything.
Then read some more.
Practice joints with tubes from old frames
Ceeway in UK for Columbus tubes or direct from Reynolds. Columbus Gara cro-mo tubes are cheap and plenty strong enough for playing with (about £12 for 1.5m lengths).
Maybe forget the MIG welder for any tubes under 1mm thick - TIG or braze is the way to go.
If you want to go crude and dirty with MIG and thicker tubes (old bike frames and ERW tube etc) then check out Atomic Zombie website. But you don't want to do that 🙂
Posted : 01/01/2014 12:00 am
Suzy Jackson of Littlefish is a self taught frame builder and has an interesting website and blog
Posted : 01/01/2014 12:05 am
Check out this thread:
http://www.sketchymtb.co.uk/Blah.pl?m-1355852080/s-all/
Posted : 01/01/2014 12:20 am
Go for it! Then post pics of your progress 😀
Posted : 01/01/2014 12:27 am
Brazing is strong enough for mtb? I may have to give this a go then. Mainly commenting to bookmark this for later.
edit: my main concern has always been the chain and seat stays, they look difficult to do.
Posted : 01/01/2014 12:40 am
MIG isn't good for frames due to its cold start nature
Posted : 01/01/2014 11:14 am
Chances are you will blow holes in the thin frame tubing using MIG. Most MIG sets dont have a low enough amps setting for thin wall tubing.
Other than that, go for it. It is very satisfying riding a bike you have made.
Check out the forums at Velocipedesalon for lots of info on steel frame building using both fillet brazing and TIG.
Stayhigh, I am pretty sure you need to be a member of Sketchymtb to view threads on there now.
Posted : 01/01/2014 11:26 am
 Olly
brazing is how lugged bikes are made. the lugs tend to be cast.
because old style road bikes dont vary toooooo much, the lugs can be standard castings, and the geometry is changed purely by changing the length of the tubes. (and a little play in the lugs)
you could braze a mountain bike, but you would be limited as to which standard castings you could use. you would have to work out your own connections for many of the joints. it is possible to make your own lugs though (if a little labor intensive).
you could weld up the lug parts from thicker steel, grind them down to a nice finish, then braze finer tubes into them.
I think you don't realise the differences.
On-one main tubes are butted, typically 1.0mm to 0.7mm or 0.9mm to 0.6mm thick.
The thinnest main tubes I would use on a mountainbike, with 853 are 0.8mm to 0.6mm, and the thinnest they make are 0.7mm to 0.5mm.
Posted : 01/01/2014 11:29 am
 Olly
in true keyboard warrior style, i certainly dont brant. No offence intended to on one!
Posted : 01/01/2014 11:39 am
It's not that difficult to build your own bike in steel of you have reasonable engineering skills, you could mig it but would need thicker tubes, so just like those £99 Chinese bikes. To build a bike that will last a long time and you would be proud to say you built it is much more difficult . The jig and joint cutting needs to be very precise or when you weld it up you are building in errors that then take a lot work and straining of the frame to correct. Give it a go, as mentioned on here ceeway will sell you the tubes and dropout etc. you will need to tig or fillet braze their tubes as even the plain gauge tube is 1.0 mm . You don't need to be trade and you can phone up and talk to them for advise, probably only cost a little over £100.
Posted : 01/01/2014 12:32 pm
it's a terrible idea, but it's quite good fun, so crack on.
fillet brazing would allow you a little room for mistakes - it's more than strong enough.
you'll need a jig - you can buy them, but they're not cheap. you can make you're own, but that's a trickier and more expensive job than making the frame.
(once you've made/bought a jig, making a frame is almost the easy bit)
It's not that difficult to build your own bike in steel of you have reasonable [s]engineering[/s] fabrication skills
Posted : 01/01/2014 12:50 pm
The jig is always the part that's put me off-too much time and money to do it right. Has anyone done this already (built the jig)? If anyone has, would they be happy to let some of us newbies borrow/use it?
Posted : 01/01/2014 1:06 pm
Olly - brazing can be done without lugs and is plenty strong enough for any type of frame - from kids bikes to car chassis (arguably better in fatigue than any other joining method).
You don't actually [i]need[/i] a jig - some people just work from a flat surface. Jigs make things much easier, but it can be quite frustrating having to spend time making one before you even start on a frame (but time well spent). As a hobbyist, for tacking together seat stay sub assemblies I still use a big block of wood and nails.
Probably best not to start the engineer / fabricator debate 🙂
I started framebuilding to make things that couldn't be bought - compared to buying an off the shelf frame it is pretty expensive / scary if you sit down and honestly add up EVERYTHING that you spend.
If you really want to do it then don't get too obsessive about alignment - if it visually looks ok and the wheel sits central in the stays then it will ride just fine. More important to do a sound structural job. Mike Burrows famously says he has (deliberately) never made a frame where the front and back wheel are in line.
So come on then - of all the posters, what have we actually built? I'll start with:-
Wooden unicycle
Folding bike - Reynolds 531 and plywood monocoque centre section
Kiddy carrying full suspension bike
E-stay rigid 29er ss (sub 16" stays)
Hardtail 29er ss / geared (16.25" stays)
Purgatory cyclocross bike (no seat tube / saddle)
Teenager balance bike
Older kid balance bike
Numerous repairs and dropout alterations, cable stop additions etc.
Current projects are a CX frame for mrs and 26" hardtail for youngest son's next bike.
For originality and inspiration my favourite builder is Julie Racing Design. Gloriously bonkers frames, beautifully made by a really nice guy:-
http://julieracingdesig.canalblog.com/
Posted : 01/01/2014 1:18 pm
Jigs can be fairly simple and cheap. This one cost me around £80ish to make.
[URL= http://i1322.photobucket.com/albums/u566/jon_m1981/SAM_0661_zps4715780a.jp g" target="_blank">http://i1322.photobucket.com/albums/u566/jon_m1981/SAM_0661_zps4715780a.jp g"/> [/IMG][/URL]
Posted : 01/01/2014 1:21 pm
Only ever repaired really, a few commencal meta 5s with cracks around the shock mounts, my old giant atx 990dh with similar problems and my first proper bike an old tange diamond back frame. Add that to loads of motorbikes.
Posted : 01/01/2014 2:50 pm
How do you go about the drop outs? Do you buy the drop outs in or make them yourselves? Fillet brazing wouldnt be an issue for me (I can braze better than I can TIG).
Jonm81 - where did you get the materials from?
Posted : 01/01/2014 3:02 pm
Hopefully the guy that converts the aluminium tandems into full sus will be along soon - they were very tidy.
I make my own dropout designs - sometimes hand cut, but often profiled from a simple dxf cad file. A place I use for work does high definition plasma and it comes out around £4 a dropout including material - they have automatic nesting software so just include my bits and bobs to use up otherwise scrap bits when cutting bigger things from full sheets. One face is perfect, the other is a bit more ragged but nothing a file and powder coat don't hide. Water jet is very clean. Lazer is somewhere in between. The material I use is the same as truck chassis crossmembers. Mild steel is a slightly lower yield strength but still fine - no need for cro-mo plate when the part is more than 5mm thick.
If brazing, think really hard about the dropout design and where / how you will heat. My first attempts were a nightmare where the cut edges of tube got cooked whilst trying to heat the thicker stuff.
Might dig out some photos later.
Posted : 01/01/2014 3:15 pm
I reckon it's easier to make one in carbon. Welding and brazing are real skills, while making a frame in carbon just requires the ability to mix the correct ratio of glue. I wish I could weld or braze, which is why I've made frames in carbon.
Posted : 01/01/2014 3:26 pm
I will agree with rich here - mixing a bit off resin and adding a bit of cloth is childs play 😉 - anyone can make a carbon frame... BUT the difficulty is getting a good carbon frame - most i've seen seem to be either very heavy, flexy or break - [url= http://singletrackworld.com/forum/topic/homemade-carbon-xc-frame-pics-and-details-as-promised ]mine[/url] was not too bad but I spent over a year researching the layup and tube thicknesses - and I still have had to modify it to my liking (bottom of this unrelated post - [url= http://singletrackworld.com/forum/topic/titanium-bars-are-they-worth-it ]clicky[/url] )
Posted : 01/01/2014 4:34 pm
Thing is, a badly joined steel frame is obviously badly joined generally speaking. A badly laid up Carbon one can look perfect on the outside..........
Even the "professionals" get it wrong, just witness the lack of gloves during lay up on the recent Alchemist Carbon wheels news story..............
Posted : 01/01/2014 4:39 pm
I guess it depends on what you're trying to do. I wanted to make a frame. I wasn't interested in making it as light as possible, just something that I could ride. In carbon, that means over-engineering everything, which is easy (you just add carbon). In steel, you still need to learn how to weld/braze, which isn't impossible, but not easy without the kit or knowing someone how can help.
Whatever material, have a go!
Posted : 01/01/2014 4:46 pm
OP
Forgot to mention - I use Inventor at work. Modelling a frame is a bit of a faff - use bikecad if you are in a hurry. The easiest way on Inventor is to use framework tool, but faffy as you need to load up your own tube cross sections (not tried this myself). Also can't print off tube mitre templates.
I did mine as an assembly of revolved tubes. Tubes done as sheet metal parts, sketch one wall cross section and a centreline, then revolve 359.9 degrees. Once all drawn up as a frame assembly, you can "unroll" the split tubes to allow printing of mitre templates (maybe not an issue if you already have a milling machine for cutting mitres using holesaws).
Posted : 01/01/2014 4:59 pm
Have a look at Ceeway's site. everything you need there
Posted : 01/01/2014 5:16 pm
The jig material came from RS components. It is only 40x40 extruded aluminium. You could probably find them cheaper online.
I got a Nova Cycles 29er tubeset and the dropouts were from Paragon Machine Works. The frameset and dropouts are not too expensive but when you factor in import tax you would be cheaper to go to Ceeways.
All in you're much cheaper buying a frame from almost any manufacturer.
For frame design, use RattleCAD. It is like bikeCAD only completely free.
Posted : 01/01/2014 6:30 pm
Every framebuilder made their first frame once - MIG isn't really suitable, but TIG or fillet brazing are roughly equivalent in terms of steels you can use and choices of angles.
You can build completely without a jig - I learned using just a vice and string - but a simple jig can make life a lot less exasperating.
If you're only going to make one frame for yourself, take your time and enjoy it - it won't matter if it takes you ages to hand-miter one tube and file down brass filets. Better that than rushing and bodging it.
Posted : 01/01/2014 6:45 pm
Wow, thanks everyone for responding. Lots of good information here... so... i'm going to do it, well at least have a go at making a frame. I want a steel 29er so that will be the aim. I will get myself a TIG DC welder on ebay, design a jig on inventor as it would be easy for me to do, and put a frame together on rattleCAD (thanks jonm81) to check dimensions. This will be a one off so dont intend to make jigs for mass production.
A few guys mentioned that they have made frames before, any pics?
I want to make something different, but i guess the first frame should be as simple as possible.
Thanks for the suggestions, advice all. I will put updates up here.
Posted : 01/01/2014 11:38 pm
As my previous comment - if it's the only frame you plan to make, may as well go wild 😉
My first frame was a spaceframe long-wheelbase recumbent with swept-back forks...
Posted : 01/01/2014 11:46 pm
stupid flickr.[img] [/img]
(honestly not as bad as it looks)
Posted : 02/01/2014 3:57 pm
Pile of photos. I've tried to pick ones that demonstrate things discussed above (and shonky ways of doing things for one-offs).
I've got an Inventor model of the jig - uses Bosch 60mm x 60mm extrusion that was heading for a skip.
Bending those e-stay chainstays was a real headache. Would have been even harder without using inventor to work out the exact angles / rotation of the tubes between each bend. The rear bend takes the tube both downwards and makes parallel to the dropouts in one hit if that makes any sense.
[img] https://lh5.googleusercontent.com/-z6uqAGLuAnw/UsXEVNRTY5I/AAAAAAAAAM0/cd_zy252_cg/s640/P1000822.JP G" target="_blank">https://lh5.googleusercontent.com/-z6uqAGLuAnw/UsXEVNRTY5I/AAAAAAAAAM0/cd_zy252_cg/s640/P1000822.JP G"/> [/img]
Posted : 02/01/2014 9:41 pm
Mick R - Those look lovely!
Posted : 02/01/2014 9:48 pm
ahwiles, that looks complicated, any close up pics of the pivots?
Mike R, Wow, that's cool. How did you bend the pipe? was thinking of using the pipe benders used by plumbers on copper pipe, but not sure if its man enough to bend steel.
Posted : 02/01/2014 10:02 pm
Thanks guys - hope it helps your projects. My first frame stuff was back in 1994 and it was impossible to get any information back then - the internet has made things much easier.
Bending thin tubes is a real pain and mine aren't perfect. There is no substitute for dies and tooling unfortunately. The 22mm stays were done with modified plumbing style benders (I tried to get them CNC bent but nowhere had the right size tooling).
Big radius bend in the seat tubes was even harder and used a home made plywood former, washing machine ballraces, a railway sleeper, scaffold tube, sand, ratchet straps and much effort 🙂
That suspension frame looks more interesting the more you look at it.
Posted : 02/01/2014 10:15 pm
This is true - I have several benders for different jobs, doing thin-wall tubes without crumpling isn't cheap.
Posted : 02/01/2014 10:17 pm
I know coppersmiths that can work wonders freehand hot bending using foundry sand and a gas torch (one did me a shower rail). Unfortunately hot bending will trash most quality frame tubes.
Posted : 02/01/2014 10:24 pm
welding is easy; (i'm crap and i could teach you in 20 minutes). getting good at welding takes a lot of practice.
I made a couple of benders for plain gauge 5/8 seat stays
[URL= http://i599.photobucket.com/albums/tt75/citizen-kane/IMGP4419Medium.jp g" target="_blank">http://i599.photobucket.com/albums/tt75/citizen-kane/IMGP4419Medium.jp g"/> [/IMG][/URL]
[URL= http://i599.photobucket.com/albums/tt75/citizen-kane/IMGP4898.jp g" target="_blank">http://i599.photobucket.com/albums/tt75/citizen-kane/IMGP4898.jp g"/> [/IMG][/URL]
Posted : 02/01/2014 11:16 pm
Here's the jig I made for gluing a carbon frame together:
Posted : 02/01/2014 11:23 pm
good stuff.
You can get mtb specific lugs, ceeway has them, lm108 from memory.
Get some practice in mitering (half round file, tube blocks and a vise is all you need)
a good miter is key.
Lugged is easier than brazed, Silver is easier than brass due to lower temp.plus it's easier to file.
make a full scale drawring,it helps.
get as many built bits as possible, dropouts, etc.
get some practice on scraps, the thicker the tubing the easier it is, you can get 1.2mm.
the paterek manual is dated but has good advice.
take your time, and remember good filing and a good paint job will make anything SEEM good-
I've been apprenticing for over a year now and have learned more in that time than in the 15 years I've been cycling/mechaniking
http://revanchebikeco.wordpress.com/
Posted : 03/01/2014 12:02 am
Tool envy 🙂
It is great to be collecting everything into one thread - keep those pictures coming.
I think the general lesson is that people improvise with the time and equipment they have available - which can range from a piece of string and a file to a full machine shop. Every method can produce good results.
Posted : 03/01/2014 10:15 am
true that.it's through improvisation that you progress.
Posted : 03/01/2014 12:07 pm
chunkymonkey
If you do want to tig weld a frame then The Bicycle Academy might be able to help. Paul Burford (of BTR Fab) can teach tig welding thinwall tubes. Plus you can use the Sputnik frame fixture that they have, and the rest of the TBA workshop.
http://www.thebicycleacademy.org/courses/tig-welding-masterclass/
or you could learn to braze to a very high standard
http://www.thebicycleacademy.org/about/fillet-brazing/
If you do get a tig welder then its worth looking at the different types, since you will (probably) be looking at a minimum of HF start plus digital display.
If you get a foot pedal then the digital display is not so important, but still useful to have.
Foot pedals can add £150 maybe £200 onto the price of a machine. And [b]not all foot pedals will give variable amperage control[/b], some are just On/Off switches.
Some cheap machines are surprisingly good and some machines are just no good for thin tubes. You need to be able to get good control at low amps, down to 20 amps.
The torches that usually come with tig machines tend to be big and clumsy to use, but you can probably get a replacement WP9 (smaller) torch for £40 or £50.
Not much is interchangable between different company's machines. There is no standard plug type eg 7pin, 10pin etc plugs. So foot pedals and torches have to be machine specific.
But gas lenses tend to be more generic, and worth getting for better gas coverage and cleaner welds.
Also a cylinder of pure argon can be expensive.
http://www.weldingtipsandtricks.com/tig-welding-bike.html
ER70-S2 (in USA) = A15 (in the UK)
This guy does a mix of tig and mig , but judge for yourself
http://www.youtube.com/watch?v=jUnVeywtTXY
http://www.youtube.com/watch?v=UMESGL0fues
Posted : 03/01/2014 2:41 pm
Citizen Kane - Some nice pipe bending jigs there, so it can be done with a plumbers pipe bender, will just have to make up some rollers that fit the diameter of the pipe.
Emanuel - I think I will buy the sliding dropouts from ceeway, I could probably make some, but will leave that for later 😉
Macavity - Can you recommend a TIG welder? I think I will have a go on some scrap pipe first, if I'm no good I will go on that training course. Having looked at the video, it looks similar to Arc Welding which I did some of at uni, was pretty good at that. Interesting that the guy did not use a proper jig. Would be nice to get a TIG welder that can weld aluminium too but, they are a lot more expensive.
I think my biggest problem is.... space! need to get rid of all the junk in the garage first. I will first design a frame on rattleCAD and get the angles, and start putting a jig together. I think that Bosch frame stuff would be the ideal start for the jig.
Posted : 03/01/2014 5:05 pm
If price is important then the R tech stuff seems to be unbeatable.
http://singletrackworld.com/forum/topic/recommend-me-a-tig-welder-to-start-frame-building-please
Even though the Rtech stuff does have all the features that you will want, it is a bit quirky.
Normally you will set the max amperage that you want for fully depressed pedal, but when you plug the footpedal into the Rtech machine the digital display will stop showing the amperage. Not unique to Rtech but not really a problem either, just that some machines do give an indication of the max current that you are going to get if you press the pedal down fully BEFORE you go full throttle.
If you are lucky you can maybe get something decent off ebay. But you really do need to have a go at tig welding first to see what is involved and what you are happy with.
A machine with HF start is really the minimum, post-gas (adjustable 0-10seconds) for shiny welds, digital display if using the torch button/switch so that you get the precise current that you want (if you are used to a mig torch with a button in the torch then it will be easy to adapt to pressing the button on the tig torch), or get a foot pedal to control the current, slope-down / crater-fill is a good thing to have. Pulse is up to you but one-pulse-a-second is probably what most people prefer.
There are other features that can be nice to have on a welder but if you do not have them then you learn to get by without.
Posted : 03/01/2014 5:31 pm
You can learn a lot from this guy
Drew Guldalian
http://www.flickr.com/photos/engincycles/
Posted : 03/01/2014 5:37 pm
chunky, re sliders.they're good and will compensate for frame misalignement in the horiz. plane,but will be damned hard to file to compensate for misalignement in the vertical plane.
I'd say build something easier first. a rack, a wheelbarrow,then an easy frame, lugged.
don't know much about tig as it's all fillet br. and lugs here, but isn't the equipment for brass cheaper?
propane and oxygen, torch. you could make do with butane but I think you'll be limited a bit.
ask peter at ceeway for advice, or come over at velocipede salon.
Posted : 03/01/2014 8:43 pm
Same here,that's why I'm using the kitchen table in my first photo!
Posted : 03/01/2014 9:17 pm
Sliders are actually harder - normal dropouts only need to me straight for one axle position, sliders need to be straight over the full range of the slider. In other words, you need to get the sliders perfectly parallel, which can be a faff.
The equipment for brazing can be cheaper, but gas can be more complicated to get and you have cylinder rental, so it's much of a muchness cost-wise, unless you're looking at a higher-end AC/DC welder (My ESAB was over £3500 with the pedal).
Posted : 04/01/2014 12:23 am
true that, I'd not considered the [s]possibility[/s] probability of misalignement in other than horizontal and vertical planes.Got three CX frames coming up with the ceeway sliders so I'm sure I'll familiarize myself...
Posted : 04/01/2014 1:01 am
Get yourself a spare set of the alloy inserts, then you can bung 'em in the jig and braze up without trashing the customer's inserts - otherwise they get a little singed 😉
Posted : 04/01/2014 1:11 am
On the subject of getting a tig welder. Some welding supplies companies have got tig machines that you can hire, just depends where you are and what you can get.
One of the slight disadvantages will be that the welder will most likely have a big heavy WP26 torch. Not really a problem, just not ideal, its still possible to make a frame with one. It will be what a lot of people learned to tig weld with, so its a good thing to start with to see if tig welding is for you.
If you were to buy a machine, and than decided that tig is not for you or you have successfully finished using it, then as long as it is a decent machine, you will be able to sell it easily on ebay.
Or, if you get a decent DC machine, but then decide to upgrade to AC/DC you might be able to trade it in at a welding supplies company.
There seems to be a fairly good demand for decent secondhand tig machines.
Posted : 04/01/2014 11:44 am
We'll be doing one for me as well, so guess who's getting the singed inserts..
There's nothing a bit of filing won't fix tho.
As Ben points out to weld aluminum you need AC and then it starts to get more complicated and expensive.
In this video it looks like he is using a water-cooled torch (WP20). A water cooler and good inverter AC machine is a lot of money.
http://www.weldingtipsandtricks.com/tig-welding-aluminum-bike-frame.html
Welding with AC (aluminium) is also very noisy , probably explains the music.
Posted : 04/01/2014 12:43 pm
Another really useful tool is the expanding heatsink
[URL= http://i599.photobucket.com/albums/tt75/citizen-kane/IMGP4703.jp g" target="_blank">http://i599.photobucket.com/albums/tt75/citizen-kane/IMGP4703.jp g"/> [/IMG][/URL]
Posted : 04/01/2014 4:30 pm
Hi All,
Would i really need a water cooled torch? the welding runs are not that long...
I would like to get a AC/DC tig, but for now would a 160A DC TIG do?
Regarding the dropouts, i like the look of the sliging ones, but they are heavy, taking inspiration from the Curtis frames... but maybe i should go with horizintal slot dropouts.
If i was to get a TIG, how would i put the cable mounts on? they seem to be brazed on usually... maybe getting the tools to braze is the better option? Though i really want a TIG welder!
Having a lathe, i can skim the head tube externally and BB internally to reduce weight, is this worth doing? I have seen steel headtubes that have been profiled to save weight.
Maybe i should learn to walk before i try running and just make a bog standard easy frame but i like a challenge.
Posted : 06/01/2014 11:12 am
Headtubes (that I've seen) are plain gauge tube, with a ring pressed on the top and bottom and brazed in place.
Posted : 06/01/2014 11:31 am
You would not NEED a water-cooled torch its just a nice to have if you are getting an AC/DC machine.
Posted : 06/01/2014 11:36 am
"I have seen steel headtubes that have been profiled to save weight"
A bit like double butting. Yes it does save weight.
For tig welding a steel bike frame a 160Amp DC machine will be fine. You are unlikely to ever need more than about 80 Amps anyway.
Posted : 06/01/2014 11:52 am
http://www.weldingtipsandtricks.com/welding-4130.html
http://www.lincolnelectric.com/en-us/support/welding-how-to/pages/chrome-moly-detail.aspx
http://www.youtube.com/watch?v=ytSrEggjz1A
http://www.youtube.com/watch?v=1nLsrcscoOA
4130 is just a type of cromoly tube similar to bike frame tubes. Just that steel bike frame tubes are very thin walled. So the tig machine that you use has to be capable of a stable reliable arc at around 20 to 35 amps
Posted : 06/01/2014 12:02 pm
Don Ferris of Anvil has more experience than most on tig welding bike frames.
http://web.archive.org/web/20061015205457/http://www.anvilbikes.com/?news_ID=22&catID=3
Posted : 06/01/2014 12:18 pm
How's your project going?
thought someone might like this:
http://revanchebikeco.wordpress.com/2014/01/26/shiny-sunny-sundays-columbus-spirit-road/ [img] [/img]
It came out allright.
Posted : 26/01/2014 5:58 pm
