I have some 13 Fox 34 Talas CTD's and although the uphill and trail performace is good - im not so sold on them when using them for DH. Now I know they are not a DH specific fork and that I've probably been spoilt by the performance of Fox 40's but I'm looking to improve them as I spend more time DH'ing on my Nomad than I ever will climbing.
Wondering if anyone has tried the [url= http://www.avalanchedownhillracing.com/Fox%2040/Fox%2034%20Open%20Bath%20Cartridge%20Kit.htm ]Avalanche Advantage fork kit[/url] ?
Just wondering if I should try a different cart or just suck up the loss on the CTD's and buy some BOS Devilles...
Like I said the 34's are a great fork I just spend more time riding DH than Climbing.
The second part of the question is has anyone had TF supply a PUSH linkage and custom CCDB for a carbon Nomad?
Again Fox CTD shock is great but I ride more DH and want a plusher coil ride!
Just ditch the talas bit and go float, FiT Floats should be mint, if not then go Avy!
2014 upgrade on CTD cart will improve things
I had heard that Fox had 'improved' the cart already which leaves a bit of a bitter taste for anyone who had just bought '13's.
Any idea what sort of money a 2014 upgrade is?
TF has supplied 2 custom CCDB's and push linkages, I sent my push linkage back as the original advert text didnt make it clear that it would work with my CCDB.
As I've posted elsewhere my Avy fork kit in a 55 RC3 Ti fork performs much better than the similar kit in my Float 36... could be a problem with my Float fork or an air spring thing: Craig at Avalanche did tell me the coil fork would feel better.
Shock wise I would do what I did and buy a DHX Air and get Craig to work his magic on it... much better than the coil CCDB I had.
Alternatively (and contraversially) get a frame with a decent length top tube, lower bottom bracket and slacker head angle 😉
Are you now running the CCDB and Push link or just the CCDB. I know the push link itself is C. £150. Do you mind me asking what the damage a custom CCDB was and what was custom about it?
How does the CCDB perform on the Nomad?
Does a V10 Carbon count coz I've got one of them already... 😛 😆
The Nomad, which for me with long legs and a shortish body, has a perfectly acceptable top tube. Just want to make it more downhill, with the ability to go uphill if absolutely necessary!
Ive always prefered the feel of coil over air - I'll have to check out the options for rear shock mods. If tried the advantage carts before but only in a coil boxxer. Did feel damn good however.
a few people have said that about the fox 34's 2013, mate of mine added extra fluid to the one chamber. said it worked better.
if your doing more DH then a CCDB is a no brainer if you ask me. if your ok with all the setting on CCDB and got the cash then get it.
i run a DSP Dueler on my nomad and feels much better than the RP23 kashima that came with it
cubemeup
Do you use a PUSH link with a rising rate to drive the coil shock or just the standard link designed for the air shock?
jus the standard link, TBH i am not really that clued up on things like push links etc
simon tuned it for me
would a push link make mush difference?
The Push link was described to me as having an 'Agressive rising rate to drive a coil shock' from what I understand the standard link is relatively linear as it is the air shock compression rate that ramps up through the travel.
pmsl sorry pal i just spat my coffee over my PC!! i would like to think i knew what you was on about but that to me is like reading Arabic.
i need to sit down and learn about suspension i think
The best upgrade i made to my nomad c was a push link and pushed rc4.
Wanted to try the link with other shocks but it never happened.
With the standard link I tried ctd trail ad, rocco, and ccdb.
With the link it was a totally different feel.
I originally had 55rc3 ti's on the bike but fairly soon went a bought another pair of deville 170 s.
Awesome.
How does it ride with the 170mm Devilles? Not too slack?
Im curently tempted by 160mm Devilles and a Push link + CCDB. Though I guess 170mm could give a little extra travel.
Hope there is not permenant damage 😛 😆cubemeup
I ran a -1.5 with the marz which was too slack for most trails. With the deville I used a straight ec headset. I was going to slack it out maybe -1 which would have been about right for me but sold the nomad.
The nomad has a relativity long cs which also extends slightly under compression so going too slack makes it feel like it doesn't want to turn.
