The standard XC version I mean rather than the UST one... Need to change my worn out Speedkings and looking for something light weight and fast for the dry.
I've been running the 2.35 version (weighed at 640g), tubeless.
Needed something that wouldn't 'grab' the flints around here quite so much, and be a bit stronger for the rear of my HT.
Good fast tyre.
The 26 x 2.0 version is listed by CRC as 450g, which seems a lot lighter than the 2.35 unless your sare the LUST version? ANy problems with inflating them?
I've run a 2.0 exception Larsen on the back as tubeless. It inflated without too much trouble but I found it a bit fragile and prone to burping. I'm now running the UST version and it has been much better.
Do they do a 2.3 / 2.35 UST version ?
I was under the impression that the 2.0 in LUST was biggest, with the 2.35 being maxpro. or exception versions.
