Anyone running a Ca...
[Closed] Anyone running a Carver EBB in a Gary Fisher Rig
Hi,
Anyone running this setup? I'm quite unimpressed with the stock EBB in my Rig. It's not a very good fit and so when you tighten the pinch bolt it tends to twist slighty in the frame. Not massivley but enough to make adjusting the chain tension a pain. I also find I have to tighten the bolt way past the torque specified in the manual to get it to stay put.
I wondered if the Carver EBB was any better?
VC
Posted : 19/12/2010 12:58 am
I'm using the standard original EBB with no problems.
In fact, I broke the original 68mm BB frame and got a new 73mm BB frame as a replacement, so the EBB is actually 5mm narrower than the BB shell in the frame.
I just nip the bolt up tight and it's never moved or creaked.
Posted : 19/12/2010 8:41 am
