As above, considering new forks for the carbon 456... was wondering if anyone has tried running 150mm 650b forks with a 26" front wheel.... how'd it go??!
CRC Bargain 650B Fox TALAS forks caught your attention?
ha, no, some others ๐
I did in my Bandit, my mate is on his spitfire. works well imo and gives you decent clearance even with big tyres up front.
Slight difference I am running a 27.5 fork & front wheel with 26" rear on my Carbon Covert
Its great
Yep - been running a 650B set of Pikes for the last 12 months on my Liteville
Feels great and have extra mud clearance
All good ๐
Abigale is running 650b X Fusion Slants on her S Works Enduro with no problems
I ran X Fusion Sweeps 160mm travel on my Zesty for best part of a year, with 26" wheels. The A2C and offset where significantly different to the Fox 32 26" fork on it originally. It was great downhill. I did have travel adjust which compensated for climbing.
160mm 650 pikes on me mega. Bob on.
Works fine. 650b compatible velvets on a whyte 19. No issues at all.
Friend had 650b rev forks and 2.5 rubber queens. No problems.
interesting. it's only about an extra 20mm on a-c, and I could probably run the forks a bit softer than I usually do to compensate a little on a-c.
