Anyone put some mil...
[Closed] Anyone put some miles on a Lezyne Mega XL yet?
 Bez
Interested to know how these are panning out for navigation. (I couldn't give a flying fig about training data, segments, etc: I just want proper, ie not just breadcrumb, navigation.)
In particular:
- How painful is it to load and sync maps? (Especially for long routes which stretch the required area into thousands of square miles.)
- How painful is it to work with RideWithGPS? From what I've read online, it seems to mean downloading from RWGPS and then uploading to GPS Root—which is clunky but not a deal breaker—but I've also seen at least one comment saying the navigation won't work without a phone being paired up while riding, which I'm sceptical of, but would be an issue. And if you upload a TCX are the cue points and POIs retained and displayed?
After having ditched Garmin for Wahoo and then gone straight back to Garmin, I've just had a frustrating weekend with Garmin again and am starting to think I might have to shelve some of my objections to the Wahoo/Lezyne approach to navigation. To be honest I suspect Lezyne falls functionally somewhat short of both, but the battery life is certainly appealing. Any thoughts? (Indeed, any other suggestions, eg Polar?)
Posted : 23/09/2018 11:03 pm
I have one, and got to the point where running it over with a steam roller would be to good for it.
Trying to load a map for off-line navigation is nigh on impossible, no doubt someone has managed it. If the marketing blurb had been as specific I wouldn’t have wasted my money it. It’s now sat in a draw in solitary confinement until I can be bothered to stick it on eBay.
Having to use a phone linked to the head unit is just not practical for real world riding. Bit the bullet and purchased a Wahoo which I am more than happy with.
Posted : 24/09/2018 7:47 am
 Bez
Ha! I'm not sure whether that puts me off the idea completely or tempts me to make you a cheeky low offer for it 🙂
Can you expand on that bit? Will it not navigate at all without the phone doing some work? It would be a bit odd if so.
Posted : 24/09/2018 10:00 am
I don't have a mega, I have a super but making routes on ride with gps and then uploading them onto GPS root is easy and takes a couple of minutes to do. Don't expect the cue points to be very accurate though. Making routes on the Lezyne app is hard work so I don't bother with that unless you just want to tell it where you want to go and let it map a route for you.
I have loaded a 65 mile off road route onto my super from the app and it took less than a minute.  The phone doesn't need to remain paired to navigate if you don't want it to, but why wouldn't you?  I have been out for 9 hours with the phone paired up and following a route and the phone was still on 65% battery when I finished with the added bonus that if someone calls or texts you, it tells you on the screen.
It's certainly not as good as as a Garmin for functionality, but it works and at a cheaper price.
Posted : 24/09/2018 12:00 pm
The issue is with third party routes, i.e. you receive a route from an event organiser, in the form of a gpx file, it needs to be converted to tcx to be transferable and used off-line. Easy enough, save as a tcx and save it in GPS Root...except GPS Root converts it back to a gpx file, and it can’t be transferred and used off-line, you must pair the head unit to your phone to use the supplied route.
Prepare a route in GPS Root, and it’s easily transferable for off-line use. So for multi-day events with several stages it is useless, unless your phone battery lasts a whole week.
Posted : 24/09/2018 1:13 pm
 Bez
OK, if I understand that correctly, it's insane.
Choice seems to be between the Element/Bolt and the Edge Explore, then. Wahoo for a clearer screen, acceptable battery life and slick connectivity; Garmin for better navigation and mapping. Hmm. I know from experience I'm not going to be particularly happy with either option 🙂
Posted : 24/09/2018 1:24 pm
I've just got an Edge Explore 820 (first ever gps) and think it's ace. Had it on all day rides (8-9 hours) and still had around 30% battery at the end.
Was a close call between the Elemnt or this, but got it pretty cheap. I'd be interested to see what Wahoo come up with when they refresh the range.
Posted : 24/09/2018 11:06 pm
