Anyone modified a f...
[Closed] Anyone modified a frame to take an internally routed dropper?
Pretty much what it says in the title,
I have a non 'stealth' (I hate that dumb description) dropper routed frame and wondered if anyone had modified/drilled a frame to take an internally routed post?
Is it just a matter of setting too with a drill, dremel and a file?
Thanks
Floss
Posted : 29/09/2016 10:43 pm
Done it with a Cove Stiffee frame. I dremeled out the seat tube from inside the bottom bracket shell, then used a small round file on the end of a bamboo cane to reach the bottom of the seat tube. I also drilled a hole at the top of the down tube behind the steerer and fitted one of these.
https://www.orangebikes.co.uk/shop/components/bolts_n_stuff/2015_internal_dropper_routing_guide
Posted : 29/09/2016 11:11 pm
