Anyone know the siz...
[Closed] Anyone know the size of fox shock bushings?
What is the internal and external diameter?
what is the width?
cheers
Posted : 30/05/2011 9:14 pm
 StuE
I fitted TFT heavy-duty bushes on my Heckler
http://www.tftunedshox.com/Miscellaneous/Mount-Kits-and-Bushings/Mount-Kits-127mm
http://www.tftunedshox.com/info/mount_kits_bushings.aspx
think you will find info you need on second link
Posted : 31/05/2011 6:52 am
8 x 22 both ends
Posted : 31/05/2011 7:13 am
What do I win if I answer โ“
I will of course give you the dimensions for the inner bush not outer ๐Ÿ˜ฏ
Posted : 31/05/2011 7:53 am
A cuddle?
Posted : 31/05/2011 8:03 am
๐Ÿ˜€ the dimensions are inner bore when compressed 12.75mm approx length top to bottom when standing up 12.66mm width outer bore 15mm.
What you upto, anyway โ“
Posted : 31/05/2011 9:11 am
cheers kael
Posted : 31/05/2011 10:35 am
Part no 08DU08 - 1/2 x 19/32 x 1/2
Posted : 31/05/2011 10:37 am
 LoCo
Bushing (DU/'hoola hoop' that press fits into eyelet?) as uplink says 08DU08
Spacers 22 M8, each top hat 10.90mm overall length, 12.70 mm external diameter on part that goes in DU bush. 6.82 mm length.
15.60mm diameter on external 'brim' of top hat which is 4.30 long.
all edges are radiused.
8mm, bore ๐Ÿ˜€
Posted : 31/05/2011 10:46 am
