Anyone know the bea...
[Closed] Anyone know the bearing numbers for a Santa Cruz Blur?
I need to replace the lower link bearings on my Blur 4X and can't see any obvious numbers on them. Does anyone know the appropriate part numbers?
Cheers!
Posted : 26/06/2009 11:38 pm
Posted : 26/06/2009 11:40 pm
I'd either email Jungle or give BETD a ring. Both have been super-helpful when I've dealt with them.
Posted : 27/06/2009 12:29 am
The Blur Pro-Pack Includes:
(4) 6901SM lower link bearings
(2) R6 2RSMAX seatstay end bearings
(2) 6800 2RSMAX upper link bearings
(2) lower pivot axles with caps and M8 bolts
rear shock shaft with caps and M6 bolts
upper link pivot axle with caps and M6 bolts
front shock shaft with M5 bolts and washers
sample pack 680 loctite
(4) lower bearing inner seals
The Blur Bearing Pack Includes:
(4) Lower bearing inner seals
Posted : 27/06/2009 8:58 am
More info here:
I've done it once. If you follow the instructions and have the VPP Press Tool it's pretty straight-forward.
Posted : 27/06/2009 9:13 am
cheers folks, I have the tool just wanted to get the bearings from a local supplier to save a few pennies
Posted : 28/06/2009 3:11 pm
