anyone got any idea...
[Closed] anyone got any idea how a dmr chieftain mkll bottom bracket goes together?
soo i finally managed to get a new bottom bracket for my dmr chieftain mkll crankset owever i dont have a clue how it goes back together theres fa too many parts??!! i really should have thought about it when i took it to bit..... anyone any ideas/photos/explanations/where i can find out?
thanks
Posted : 10/03/2009 8:39 pm
dunno, spend 30 seconds googling for dmr's website?
Posted : 10/03/2009 9:13 pm
ah thanks for bein cocky nob cheese however that doent really help in any way!! because its not on there!
Posted : 10/03/2009 9:46 pm
if its a BMX BB then its straightforeward
press cups into frame
pres bearings into cups
rubber mallet the axel through (some may need the axel putting in before the bearings)
put the NDS crank on, tighten up the axel bolt, tighten up the pinch bolt, hammer the arm on a few more times to make sure its all the way on.
put the chairing on the DS arm (might need a spacer between chainsing and crank), slide it ont the other side tighten the axel bolt
look for a gap between the chaining/BB, guess how many spacers will fit in the gap, the aim is to add spacers till the chainring is held in position and the bearings are slightly pre loaded (and the whole lot doesnt creek)
hope that helps.
Posted : 10/03/2009 10:26 pm
thanks mr thisisnotaspoon very helpfull!! ill have another go with those guidelines and see what i can come up with. cheers
Posted : 11/03/2009 7:14 pm
