I have a superstar trizoid 120 POE hub, which is a Chosen hub from Taiwan.
Its the same as a Halo Supadrive, for which spares are available.
The ratchet ring needs replacing. The ring is only £5 but the tool is £31 so I thought I would check here to see if anyone already had one they would loan or sell.
Has anyone done the job? Did the ratchet ring come out OK?
My other option is to try and cut the ring thats in there, this risks destroying the hub though - anyone done that?
Looks like this: https://www.tritoncycles.co.uk/tools-c10/workshop-tools-c129/supadrive-drive-ring-tool-p13654
no one out there done this?
I just bought the tool, eventually got the ratchet ring off after heating the hubshell with a blowtorch and heaving on it for an hour with the tool clamped in a vice.
So.... if anyone out there reads this, and has a halo supa drive or superstar trizoid 120poe in need of a new ratchet, I have a tool which I'll sell you.
The halo supa drive ratchet ring and pawls from triton cycles fit the superstar trizoid 120 hub perfectly.
Are the ratchets a weak point on this hub? I've just bought a wheelset with the Chosen 120 poe hub
I don't think so, I couldn't find anything on the internet about them. Superstar sold loads and I guess halo have sold loads (and still sell) supa drives
Mine had a collapsed inner freehub bearing, this meant the freehub was running offset and wore the pawls and ratchet.
Easy enough to replace once I had the tool.
Pawls are £12.99 and ratchet ring £4.99 from triton. PM me if you want to use the tool I bought!
