anyone gone double ...
[Closed] anyone gone double rings and bash guard and regretted it ?
 mboy
Not being rude, but there is some B0ll0cks spouted on this forum! All this crap about "needing" a 44T chainring on a mountain bike offroad. You sit down with a calculator and work out your gear ratios. You will find that if you're running a 36T ring with a bashguard, that in the 9th cog on the back your gear ratio is still taller than 7th on the back with a 44T ring on the front! How many times OFFROAD do you use 8th and 9th on the cassette with the chain on the outer chainring? Honestly now. Onroad on a big downhill, then yes fair enough, but I've never used 8th and 9th on the cassette with a 44T ring up front EVER!
36/11 = 3.2727
44/14 = 3.1429
Have a triple on my hardtail cos I intended it to be able to be used for a bit of road commuting (job permitting) as well as an XC bike. My Full sus bike has a 24/36 bash setup though, and the bash gets used! Was riding in the Peaks the other weekend, don't know what trail as it was my first time up there, but this trail we rode I had to walk a few bits cos it was so technical (hey I'm no skills god, nor was I on a trials bike!), but to even ride quite a lot of it the bash guard was getting used quite a lot. Suggest that some of the people that don't see the need for a bashguard at all would have shouldered the bike down the entire trail!
Oh, and FWIW, bashguard is generally a bigger requirement on a full sus bike IMO, especially if you've got a fair bit of travel as the BB gets far closer to objects when the suspension compresses than is obviously possibly on a Hardtail.
Posted : 07/03/2009 10:20 pm
22/36, with a single roller chain device to keep it all in place when playing rough. 12-28 cassette for local stuff, 11-32 for trail centres with short cage rear mech. I've never used 8th or 9th on either. Thinking of losing the bash guard as is pretty superfluous.
Big bike more like 38 single ring, MRP System 1 and a 13-27 road block (OK I'm showing off now..)
Posted : 07/03/2009 10:32 pm
I've just ditched the big ring on my HT and fitted a lovely Dark cycles bash ring. I started off running a 36/22 & 11-34 but have since moved back to a conventional 32/22 & 11-32 as most of our riding up here is pretty steep. My set up is still at the experimental stage bit i still reckon its all i need for offroad.
Posted : 07/03/2009 10:38 pm
A big ring is useful. It can cope with losing a few teeth. ONly get a bash if you ride relly technical
IMHO
Posted : 07/03/2009 10:39 pm
Another benefit of the bash guard - it'll last forever, more or less.
Posted : 07/03/2009 10:42 pm
so in order to have a bash ring you should only be riding really technical stuff? biggest load of rubbish ive ever heard
Posted : 07/03/2009 10:44 pm
Jeez Bomberman - I've ridedn all those trails he said for years ned never needed a bashring. ALways ridden triple and never had a problem despite rocks bashing off everywhere.
Peak is rocky, but doesn't have wheeltraps where you'd bottom out yer bike.
Sounds to me like he had a spot of bad luck.
Like I said, the big ring can tolerate loosing some teeth. Also would a bash ring stop the spider bending out of shape? I doubt it. If the impact was hard enough to do that then the spider is the weakness, not the ring.
Posted : 07/03/2009 11:03 pm
One of the main reasons I went to two and a bash was that I was getting chain suck in the middle ring when things got claggy and never really used the big ring, figured shortening the chain was the best way forward and may as well swap the big ring for a bash, works fine and I`ve never felt I needed more gears.
The ring I took off did have teeth missing, chain clatters a lot less too.
Posted : 07/03/2009 11:33 pm
Did you need front suspension? Disc brakes? Nobbly tyres?
Posted : 07/03/2009 11:40 pm
The big ring certainly helped drop others on the flats or descents (and uphills sometimes)
If you don't use the big ring then lose it. But I ride in the Peak all the time and never considered getting rid of it.
All IMHO of course. If you want to fire more cheap pop shots then go ahead, I don't care (obviously I do) but he's asking for an opinion and I'm giving mine based on 10 years of riding in the area along with many others.
Posted : 07/03/2009 11:47 pm
I have just bought a double SLX , i looked at my all mountain bike , the outside ring is completely chewed and chunked up , the teeth are bent .... i thought "when was the last time i shifted onto this ring ?"
So going the double was a no-brainer .
Also you dont have to be hitting stuff with your big ring to wreck it .... 95% of the damage to mine is from flicked up rocks.
Posted : 08/03/2009 9:24 am
Do you ride down scree slopes? Only way I've broken teeth off is by riding into things very hard.
The main advantage of bashguards is that the look damn cool.
Posted : 08/03/2009 10:35 am
My Trance has quite a low BB and I ride trails that are slightly more technical than some bland trail centre in North Wales that apparently has a black route. Plus I rarely use the big ring since I stopped doing XC races around a muddy field so I have a nice, lightweight bash guard instead.
The possibility of bending teeth on the big ring is one less thing to worry about and luckily the having a bash guard fitted doesn't impact on the riding of my fellow riders, though it gives the STW moaners something to bleat about.
Posted : 08/03/2009 10:54 am
Some of the trails i ride are very rocky , and here in oz its as dry as .... so it doesnt take much to flick some up when belting down hardpack singletrack .... i even have chunks out of my crank arms 😯 Thats why i have went the el-cheapo SLX too , no point munching XTR's !
Posted : 08/03/2009 11:47 am
What part of oz are you in. I'm down tassie.
Posted : 08/03/2009 10:12 pm
I ride the Peaks with 36/22 and bash. Only ever run out of gears on road but have plenty of battle damage to bash guard to justify its existence. My original outer ring had quite a few missing teeth, mostly from rocks flying up and hitting it rather than it hitting static rocks. I guess this doesn't happen if you're only going at a "steady" pace 😉
Where I was VERY thankful for the bash was riding in the Sierra Nevada. I "needed" all my suspension, my disc brakes, my wide bars, my bash ring and all the other great stuff that helps me ride faster and harder without breaking me (too often!) or the bike bits that - as many posts on STW point out - are stupidly expensive at the mo'
Posted : 09/03/2009 12:04 am
CrazyLegs - you're roadie-ly wrong IMO 🙂
[i]"Bashguards have their place but that place is on full on DH bikes."[/i]
What absolute twaddle!
I haven't got a big ring on any of my bikes.
Triple chainsets have their place - on touring bikes.
And if you're so bothered about weight saving - why do you use such long stems? ;-P
Posted : 09/03/2009 1:06 am
Riding mostly woods, up and down. natural type terrain with trips to lakes occasional trail centres.
Running 22/32 11-26. its all I need.
If Ineed a higher gear I free wheel (if i want to go faster on the road, I ride a road bike)
I can get up any thing ridable with my lowest gear.
Bash guard good for for getting over logs
A nice short chain is another benefit
To me its not weight sving/ style, its what works
Posted : 09/03/2009 1:45 am
I have double and bash on my geared Inbred and my Remedy 66. I hardly ever use a big ring, the only place I can make use of one is on Tarmac, there are no hills offroad in North Wilts where I'd be going fast enough to need or want one, and, as a number of people have pointed out, it's rocks flung up by the front tyre that does the damage. Round here lots of the trails have big chunks of limestone either wash out of banks or old dry-stone walls, and some can be the size of a soup plate. When you go over at speed the back edge flicks up and slams into the rings. I've wrecked a RF big ring like that, the impact lifted me clean off the ground and nearly over the bars. My bash rings have both got impact damage to them, and I don't ride [i]that[/i] fast. It happened with my old SuperVee, with barely four inches of travel, and left a thumbnail sized dent in the downtube, as well as a broken XTR big ring, and the 'bred and Remedy are both 6" bikes, and I go faster on those. Those who ride triples without problems, fine, just don't sneer at riders who find a 2x9 with bash more than adequate. We're not racing, for Heaven's sake!
Posted : 09/03/2009 3:01 am
+1 for that. 22/32 and 11-32 running on a 105 rear mech. Nice high chain tension, never had chainsuck. Shifts great. Climbs lovely in 22:22 with a great straight chainline. I know cos I was grovelling up Jack Bridge for the 2nd time yesterday afternoon and looking down at it.
With a long arm mech and enough chain to run a big ring, it'd be wrapped up backwards and flopping around.
Posted : 09/03/2009 8:10 am
He's right, you know.
I sat down and worked out all the gear ratios before fitting a 36 + bash to my Pitch. Basically, in 36/11 you loose top gear off a 44/11 and bottom gear off a 32/34. (It's not quite that exact, but near enough)
In use, I found it easier (which I wasn't expecting) because I spent less time switching between middle and big rings. With the 36 it puts me in a more useful gear more of the time, and then I just bang down to the granny for long climbs
I reckon I might get more even wear on my cassette as I'm using all the cogs, not mainly the middle few as I was before, when I rarely used the top 3-4 gears....
I only span out once at Afan on a long fireroad descent on W2 when racing someone, and I'm a big gear lover!
I'm thinking of doing it to my other geared bike when I run out of big rings, but I've got at least 2 spares right now
Posted : 09/03/2009 8:18 am
Fitted a bash gaurd for a France trip last year, with a 22/32, it's still on.
I suppose the only time you would miss it would be if your riding with guys still running with one, I do and it make's them no faster, up or down.
So I'm gona stick with it.
each to their own I suppose
Posted : 09/03/2009 8:23 am
Running a 24/36 with an 11-32 cassette and double and bash for the last 3 years. Found an e-thirteen bash that is [i]just[/i] bigger than the chain. Works just fine for me and vindicates what mboy calculated above.... and I wont be changing.... it does nicely for all my riding.
Posted : 09/03/2009 8:46 am
*puts hand up
Bashring user
I bought a bash ring yesterday for my Pitch (partly 'cause it has an XT touring chainset on it and the mech won't clear the 48... or is it a 46?)
I have had a DRS on the Patriot and that gives a nice and secure feeling for the alps, though I didn't actually bash it.
Its probably worth pointing out that on wet logs they also serve as a nice sliding surface when you can't clear the log with the chainset; you know... so you don't get that 'dead stop' feeling as you spike the ring into the log?
Posted : 09/03/2009 9:16 am
I've just re-fitted my raceface bash ring to the pitch, not sure wether to fit the 36T ring I have kickign about or just leave the 32 on, as I never seem to run out of gears when "pootling" around trail centres 😆
Just a quick question, when shortenign the chain on a full suss, whats the general rule of thumb, is it BIG/BIG + 2 links (what I used on my HT) or is there another method?
Posted : 09/03/2009 10:05 am
Anyone who hasn't felt the need to go 2 ring / bash yet, needs to move to a part of the country where there's some interesting riding 😉
Posted : 09/03/2009 10:17 am
Blazin-saddles - Member
IMO a big ring is only required for racing or your doing a fair bit of road.
Horse Poo! A big ring is required if the speed you want to go can't be acheived on the middle ring, I was in the big ring (44) for about 80% of Llandegla yesterday.
And I bet you spent most of the time in the middle of the cassette using gear ratios that are available using the middle ring and all of the cassette???
Posted : 09/03/2009 10:19 am
Big/big +2 like you said, but you also need to allow for chain growth, so as a precaution, do the above with the rear suspension fully compressed, i.e, air out of the shock or remove the spring. This guarantees that you won't rip the rear mech off at full travel if you happen to be in the wrong gear!!!
Posted : 09/03/2009 10:24 am
 juan
Bash ring user for 4 years now 22/32/bash that 2 years after all my friends (because I was too poor to buy one) and way before it became fashionable. I just really cant see the use of a big ring... Unless you use your mtb on the road. And even so it has to be flat or downhill roads.
Steep Rock/tech playground = double + Bash
Non steep non tech playground (à la lordswood) = SS (in my opinion)
Inbetween the two you are not going to be on the big ring anyway. Plus as brant say (crap I am going to need a mouthwash for that) shorter chains is much nicer.
To be honest I would only see the use of the big ring on a DH bike...
Posted : 09/03/2009 10:27 am
Cheers 2hats, chain fettling here we come
Posted : 09/03/2009 10:30 am
I have run a steel hardtail in the lakes & stanes for the last few years. I changed mine to a double & bash (E13) purely from a financial perspective. I was sick of buying new big chainrings. I could guarentee that on the first ride with new chainring i would have a couple of teeth mangled. Not such a big deal but it got to the point after a month or so where i couldnt trust the big ring to put any power into it as it would slip due to loss of teeth.
As i said 3 yrs ago i changed to bash guard. I havent really missed the big ring and tbh i set up the fron mech so IF i do any events i can put the big ring back on with a longer chain in 5 mins. All the marks on the bash guard and my peace of mind justify my decision imo.
I've worn out the big ring first on my last two XTR chainsets. I don't think I'll be replacing it with a bashring any time in the near future. 😕
Posted : 09/03/2009 10:32 am
I suppose it depends absolutely on where and how you ride. I'm certainly not saying "I'm right, you're wrong" as it's all opinion and preference anyway, but for what it's worth I wouldn't want to be without my big ring - I ride most of the time in it and usually in the upper gears at the back as well to allow me to keep speed up. The fact that it's the big ring that gets changed most often supports this. Part of it's becuase I don't get out much and want to train hard when I do. I suspect the other big difference is that I ride where the hills tend to be short and fast - it would certainly be a different story in a hillier part of the country, which is where a lot of other posters seem to ride.
Each to his own though, so please don't shoot me down for expressing what is just my opinion.
Posted : 09/03/2009 6:29 pm
I currently use 26/36/bash set up with a 11-34T cassette. Which works perfectly for. 26:34T is lower enough to winch up most stuff. If I can't get up in that it'll be quicker to push. The 36T ring helps on a certain local pedally offroad descent.
Doing the math, you lose the top 1.5 and bottom 1.5 gears (that make sense?)
Found 22/32/Bash fine but not quite perfect. The old bashring I took off before fitting the new set up was absolutely mullered. Lumps taken out of the polycarb. It did get a whole summer of alpine abuse though.
Would run 22/32/Bash again though, if I lived somewhere steeper.
Posted : 09/03/2009 9:49 pm
Doing the math
[url=
Posted : 11/03/2009 1:18 am
what, like the peaks? yup already lived there, and hopefully moving back soon
ive hit my chainring more times at cannock! Mainly because you pump corners there whereas in the peaks its more foot out cornering or tight switchbacks than berms.
I ran a 38t single in the peaks for a few years, big thick middleburn one. Climbs up most stuff {even poters clough), but as 90% of riding in the peaks involves a road at some point i kept spinning out keeping up with the rest of the group.
Posted : 11/03/2009 9:25 am
OK, here's the MATHS! 😉
(All worked out in gear inches in the table below)
As you can see a 36/11 is nearly equivilent to a 44/13, meaning you effecively only loose top gear from a 44t ring.
So, to those that say they NEED a big ring, how many times do you select 44/11? Not very flippin' often!! No telling porkies now! 🙂
At the bottom end of the 36t scale, a 36/34 is virtually identical to a 32/30, so you only loose 1 gear at the lower end: So change to granny earlier. No problemo.
- - - - [u]44 - 36 - 32[/u]
11 - 104 85.1 75.6
13 - 88.0 72.0 64.0
15 - 76.3 62.4 55.5
17 - 67.3 55.1 48.9
20 - 57.2 46.8 41.6
23 - 49.7 40.7 36.2
26 - 44.0 36.0 32.0
30 - 38.1 31.2 27.7
34 - 33.6 27.5 24.5
Posted : 11/03/2009 10:34 am
I think the main benefit of having a triple over a double and bash is that you're spreading the wear over more teeth, I found, when using a double and bash, I'd go through casettes and middles pretty fast because i was hammering the small sprokets and middle combo for most of my riding, other than that no big difference..
Posted : 11/03/2009 10:38 am
But a steel Deore middle ring is £8. How much is a big ring?
Sorry, I've got to say I'm a total convert to 36t/bash. It makes sooooo much sense to me!
Posted : 11/03/2009 10:48 am
Yup pod, middles are cheap, but usually the casette goes as well, due to spending more time in the small cogs, then it gets expensive..
Posted : 11/03/2009 10:50 am
 juan
Buy only the small cog then...
Posted : 11/03/2009 10:52 am
LOL at the Llandeggla big ring comment. FFS go somewhere proper if your going to spout off shite.
I like to build trails, latest one is slow and steep with slow drops into corners, you cant ride it with a triple unless you are willing to stop dead and bend your teeth and then fall off onto sharpened spikes. I did that on purpose.
If I get my way some of the new official XC bits on Cannock Chase wont be rideable by these roady type MTBs with no skills weekend warriors unless they want to carry their bike back in a bag.
Posted : 11/03/2009 10:57 am
 juan
Wanna marry me? I am perfectly housetrained.
Posted : 11/03/2009 11:00 am
I think not.
When using a 32/44 you tend to spend all your time in the middle/lower end of the cassette, because you don't use the smaller sprockets as you have a bigger ring. With a 36 only, I'm using the whole cassette all the time, thereby evening up the wear!
EDIT - It's 6 of one and half a dozen of another, really. We're both right. And both wrong
Posted : 11/03/2009 11:04 am
Hardly the best example to use, one of the least technical of Welsh trail centres, all full of smooth, lovely sculptured but completely unchallenging singletrack.
Actually there was a slight lip to the patio outside the cafe that could cause a nasty nip to a big ring, you must be very skilled to manage that section of trail.
Posted : 11/03/2009 11:09 am
Page 2 / 3
