anyone else always ...
anyone else always have a problem with presta valves?
I like presta simply because it has a locking to stop the valve being pushed into the wheel when I’m pushing on the pump
You can get schraeder valves with lock rings as well, they are less common but definitely handy (as long as you don't use them as a fixture to swing your pump off of).
As I said before, Schraeder allow higher flow (never had an issue seating tyres even on my basket case 729 with the bent lip) and don't clog as easily.
I don't buy the less permeable argument either. Shocks, forks, gas rams and air cylinders all have schraeder cores. I have a modified air rifle with an 800psi airsoft tank that hasn't dropped pressure since it was last used a few years ago.
That test (if there was an actual test and not just uninformed "common knowledge" nonsense) was probably carried out comparing decent presta tubes vs whatever cheap crap schraeder tube was lying about.
Posted : 30/07/2022 3:37 pm
They are used in a lot of applications. For high-pressure critical applications, much higher quality cores are used. Those aren't necessary for tyres running at 30 psi.
Posted : 30/07/2022 3:46 pm
So if I'm running tubeless with sealant and I put schrader converters onto my prestas I could leave them on and use my JoeBlow pump with dual inflation head. No need to take them off other than any sealant maintenance? Is there a downside to that?
Edit: running at less than 30 psi
Posted : 30/07/2022 3:57 pm
You want a push and lock pump. Any hand pump, if you are ham fisted, get one with a mini hose, it removes stress on the valve.
Posted : 30/07/2022 6:09 pm
They are used in a lot of applications. For high-pressure critical applications, much higher quality cores are used. Those aren’t necessary for tyres running at 30 psi.
True but their quality is determined by their ability to hold pressure. Why would the two be any different assuming the valve seat is clean and isn't distorted from over tightening? The design principle is essentially the same, it's a brass valve held on its seat by the pressure behind it any additional tightening force (in the case of Presta) is hardening the valve face onto its seat which, over time, is actually more likely to make it leak.
That aside, there are probably more factors that would cause a leak before the valve can be blamed.
Posted : 30/07/2022 8:56 pm
Page 2 / 2
