Anybody using Avid ...
[Closed] Anybody using Avid Elixir brakes with Hope floating rotors?
7 Users
As the title but without having to make any modifications to calipers etc?
Posted : 02/04/2010 1:06 pm
Dunno about elixers, but they work fine with juicys. As far as I'm aware (with the exception of hope vented rotors) a rotor is a rotor is a rotor...
Posted : 02/04/2010 1:12 pm
As what tree-magnet says, they work fine with Juicy's and the Elixir is basically the same caliper with just a different lever
Posted : 02/04/2010 1:20 pm
Juicy Ultimates don't without modification and floating rotors. Had to remove some metal to get it work 🙂
Posted : 02/04/2010 1:24 pm
Yep, absolutely fine, with Elixir CR callipers and XX callipers.
Juicys are not the same callipers either, particularly the Ultimates.
Posted : 02/04/2010 2:26 pm
no issues here bud
Posted : 02/04/2010 2:53 pm
I had clearance problems with the same combo.
Filed the caliper down a tiny bit and that solved the problem.
Posted : 02/04/2010 3:51 pm
Sounds like the tolerances vary then!
Posted : 02/04/2010 3:56 pm
