Anybody ride an old...
[Closed] Anybody ride an old 80mm original Anthem?
What are your thoughts on it and what fork length do you use?
Many thanks.
edit [url= http://singletrackworld.com/forum/topic/anyone-built-up-a-giant-anthem-frame ]found some[/url]
Posted : 27/02/2012 9:33 pm
Yes been riding one for years, fantastic xc bike mines got float 80mm on the front but you would get away with 100mm.
Posted : 28/02/2012 12:05 am
I ride an '06 anthem 1 with 80mm front and the standard 90mm rear, its great, rides like a hardtail most of the time, with some added comfort! I run it fairly tight with fast rebound, but it feels really fast. I replaced the twangy manitou R7 fork with a SID which is soooo much nicer. SID I bought is standard 80/100mm. I'm currently running at 80mm as that is how I bought it off chain reaction, (as the 80mm version of the same fork was more than £100 cheaper than the same fork just with the spacer taken out!) Next time I get the fork serviced, I'm going to try it at 100mm.
I emailed giant before buying the SID, and they reckoned that it would be great set at 100mm but I haven't tried it out yet!
Posted : 04/03/2012 11:21 pm
 kcr
When I had to replace the original 80mm forks on my 06 Anthem I moved up to 100mm. I used to get a lot of pedal strike with the original setup, but this disappeared with the longer fork.
Posted : 04/03/2012 11:42 pm
Your 80mm SID will have the spacer in. Very simple to remove spacer, DIY job.
Posted : 05/03/2012 8:31 am
I had an 07 Anthem with 80mm forks, it was fast but it didn't give me much confidence on steep down hills, it had a crazy-steep head angle like 72 or 73 degrees if I remember. It liked putting me over the bars (OK it was my fault for being a skill-less numpty but it's very unforgiving :p ).
Posted : 05/03/2012 8:47 am
