Anybody got any 650...
[Closed] Anybody got any 650 x 47 WTB Horizons
[#9447894]
If so could you do me a quick favour and measure diameter when inflated and actual width when inflated please?
Posted : 20/07/2017 1:21 pm
[url= https://preview.ibb.co/bsqEn5/IMG_0128.jp g" target="_blank">https://preview.ibb.co/bsqEn5/IMG_0128.jp g"/> [/img][/url]
[url= https://preview.ibb.co/neDpLQ/IMG_0127.jp g" target="_blank">https://preview.ibb.co/neDpLQ/IMG_0127.jp g"/> [/img][/url]
[url= https://preview.ibb.co/kVrn75/IMG_0126.jp g" target="_blank">https://preview.ibb.co/kVrn75/IMG_0126.jp g"/> [/img][/url]
[url= https://imgbb.com/ ]free pic hosting sites[/url]
Posted : 20/07/2017 1:28 pm
Many thanks Dirtyrider, my stelvio may be getting a pair shortly and I wanted to double check clearance before ordering 🙂
Posted : 20/07/2017 1:41 pm
 aP
What do they ride like? I'm using Compass Loup Loup Pass 38s at the moment.
Posted : 20/07/2017 1:43 pm
Was just going to ask the same question but I'm running the Compass Barlow Pass 38's.
Posted : 20/07/2017 1:47 pm
I've only done 4 rides on them, and nothing overly long yet, but i can easily hold 30kph on flat roads (Lincolnshire) and for the flat bridleways and tow paths round here they are great (not ridden in the wet yet)
is there probably better tyres out there no doubt, early adopter and all that, had the same when i bought a Krampus, choice of 1 tyre, i guess it just depends how you split your riding and what your local gravel/trails are like (the uk isn't Utah, theres not 200 mile gravel loops etc)
i do wonder how much road speed id lose if i switched to WTB Byways, Terrene Elwoods, or the new Panaracer Gravel King 650b x 1.9" (spotted on Instagram)
Posted : 20/07/2017 8:15 pm
The elwoods are a fair chunk of change slower, but grippier offroad, the gravel king sk are a touch slower but also grippier, the slick gravel kings are prety much the same tyre.
Posted : 21/07/2017 7:17 am
Curious to know what the 47 relates to, given what I can see on [b]dirtyrider[/b]'s pictures. At least I know they'll fit a Bokeh 😀
Posted : 21/07/2017 7:22 am
Curious to know what the 47 relates to, given what I can see on dirtyrider's pictures.
I was thinking the same! 37?
Posted : 21/07/2017 7:46 am
Now you've got me thinking if those wheels and tyres would fit in a CdA ❓
Posted : 21/07/2017 8:32 am
its a 650b x 47mm tyre
https://www.wtb.com/collections/road-plus
Posted : 21/07/2017 8:41 am
But your first image shows it to be 37mm wide?
I stared at the pic for about a minute trying to decide if I was being stupid!
Posted : 21/07/2017 8:45 am
Just measured my voayager hyper 35's and they are actually 38mm wide and the 38's are 40.
Not sure what advantage I would get from those Horizons now other than tubeless and slightly quicker handling.
Posted : 21/07/2017 9:51 am
Although the sidewalls are 5mm taller so maybe some extra cushioning.
Posted : 21/07/2017 9:57 am
It's claimed [url= http://www.gravelcyclist.com/bicycle-tech/review-wtb-horizon-road-plus-650b-tubeless-ready-tires/ ]here[/url] that they measure up at 48mm when mounted to crests 😕
Posted : 21/07/2017 10:10 am
PJ266 - Member
In the end I figured he'd lined up the zero with the far side and was showing the 47mm vertically on the near side.
The angle meant we couldn't look vertically down the far side.
Posted : 21/07/2017 10:23 am
That's a hell of an optical illusion but I can see it now
Posted : 21/07/2017 10:50 am
I measured them as 47.5-48mm on some WTB I25 rims. Around 684-685mm OD.
Not as 'supple' as the Panaracer-made tyres, ie basing the comparison on Pacentis made by them rather than Compass tyres which are similar casings if not lighter - not sure. The Compass tyres appeal to me as the Pari-Moto or Panaracer Gravel King is a very smooth, efficient / fast tyre but I lost way more time fixing flats from thorns and tiny flints - the lower pressure seemed to make them less flat-prone than I expected but 2 a day was pretty common. I've had 2 flats in well over a year on Horizons, one of those was a flint slice. I might go back and try the Compass 650x48s .. locally to start with. Has to be said the Horizons don't feel quite as cushy as they could, but they're cushy enough and the reliability is a benefit.
Posted : 21/07/2017 2:56 pm
I am using them on some Pacenti TL28 rims.
30-40 psi depending on terrain. Was previously using G One 700x40.
Comfier, same average speeds as before, seem faster to accelerate but lose momentum quicker.
Surprisingly grippy off road except in sloppy mud or wet chalk.
Have been great in Brittany the last few days with fully loaded panniers on mix of road & gravel tracks.
I finally got a puncture today that wouldn't seal (turns out there was virtually no Stan's left) so had to chuck a tube in. Instantly felt less supple at the same pressure as tubeless, will be redoing as soon as I can.
Posted : 21/07/2017 3:44 pm
