Anybody bought a ne...
[Closed] Anybody bought a new Air shock that seemed stuck out the box?
I have,Suntour Epicon 140mm R to be precise.Could the seals be stuck?Will it work on the bike when i sit on it.Hope they haven,t sent me a dud.Any of your experiences greatly appreciated.Monkey.
Posted : 01/09/2012 6:22 pm
If it's aired up, you won't be able to compress it by hand. In fact, just to test, I just emptied an RP23 and it's pretty hard to compress even with no pressure.
Course, this doesn't mean yours isn't knackered ๐Ÿ˜‰
Posted : 01/09/2012 6:35 pm
I can't hand press it in with or without air.If its been stood for a good while could it be stuck to one of the seals. Will it loosen with my big arse on it.
Posted : 01/09/2012 8:58 pm
Not sure about the Epicon, but Floats have a nitrogen charge in the region of 300-400psi, which makes them difficult to compress regardless of how much air is in them, may be that the Epicon has something similar.
Posted : 01/09/2012 9:34 pm
Even without air you won't be able to compress it by hand.
The pressure/charge in the damper provides a reasonable spring in itself.
Posted : 01/09/2012 9:51 pm
Yeh,it does have a nitrogen damper.That must be it.Cheers.PS any advice on fitting the thing.How do I avoid the rear end falling in on itself.
Posted : 02/09/2012 1:44 am
Use a workstand? It doesn't really matter if it briefly 'falls in on itself' though.
Posted : 02/09/2012 9:27 am
