Any way to make gar...
[Closed] Any way to make garage less dusty for using turbo in?
Hi,So currently my turbo is at back if the garage.
I do sweep it etc but think that after using the turbo I find I'm clearing my throat/chest and i'm beginning to wonder if it's dust in there.
Two questions.
1) Anyway to (cheaply) check the air pollution?
2) Make it cleaner in there?
P.S I'm a bit reluctant to move turbo to be next to the open door because my garage is on a communal car park and I'd be too self conscious!!
Cheers for any suggestions...
Posted : 28/07/2016 8:16 am
Floor paint helps a lot IME.
Posted : 28/07/2016 8:17 am
As does a bit of carpet, etc attached to the bottom of the up and over door...
Posted : 28/07/2016 8:19 am
some sealant will keep the dust down - they suggest you use it prior to painting in any event.
[url= http://www.wickes.co.uk/Wickes-Concrete-Floor-Sealer-Clear-2-5L/p/214270 ]http://www.wickes.co.uk/Wickes-Concrete-Floor-Sealer-Clear-2-5L/p/214270[/url]
Posted : 28/07/2016 8:21 am
I spent just £60 or so putting down the rubber inter-locking floor mats from CostCo/Halfords, I can't remember which.
Quicker than painting, easier to replace a damaged tile than carpet, easier to clean than carpet and definitely controlled the dust instantly...
Posted : 28/07/2016 8:29 am
Oh, plus I got some expanding foam to fill the gap between the bottom of the door and the floor, plus the gaps around the inside construction of the door itself. Had a year or two of going over the foam with kids, toddlers and motorbikes and its proved to be pretty much perfect.
Posted : 28/07/2016 8:31 am
Seal and paint the floor .
Posted : 28/07/2016 11:23 am
Definitely seal and paint!
Posted : 28/07/2016 11:24 am
 marc
Cheap carpet is, er, cheaper than painting.
Posted : 28/07/2016 12:02 pm
Hose pipe and wash it out?
Posted : 28/07/2016 12:05 pm
 RicB
Vacuum the dust up, seal floor with 1:5 PVA: water applied with a fence painting brush. £10, couple of hours.
Posted : 28/07/2016 1:12 pm
yep, as others have suggested.
Seal/paint the floor, cheap white emulsion on walls, cheap carpet/foam tiles on floor..
Posted : 28/07/2016 1:52 pm
Cheap linoleum? A few roll ends will cover a garage.
Posted : 28/07/2016 2:38 pm
Great responses - cheers. Whilst I'd love to paint it (and nearly did when bought thd house, even bought the paint) ...the garage is now too full to be able to paint. However, the idea of interlocking mats sounds good, or even the lino suggestion.
Cheers for the help...
Posted : 28/07/2016 3:52 pm
This. I assume you can't regularly dampen down the floor given the "too full" comment ? Dust ime will be coming from the floor itself "breaking down" which is why the sealant / paint makes so much difference but I assume you are well aware of this.
Finally empty the garage out on a nice day, wash floor down and get it painted. Stuff back in when dry. That sorts the problem rather than a bodge
Posted : 28/07/2016 3:57 pm
I did this a few years ago (Costco, and more like 30quid for a single garage at the time) and they have worked very well. I used cardboard boxes as underlay and added some carpet at the workshop end.
Painting the walls white makes a difference to lighting.
Inspired by [url= http://www.garagejournal.com/ ]Garage Journal[/url], I then painted the lower 1/3 of the wall grey and added a red stripe above the grey, below the white -It's the best room in the house.
Posted : 28/07/2016 4:12 pm
I got a cheap industrial type vaccum and a roll of rubber matting. I Hoover when the mud and detritus off the bikes gets to the point I know it will cause me aggro and its stayed pretty clean for a garage since.
Posted : 28/07/2016 6:53 pm
I used Mototiles is was quick and made a remarkable difference.
Posted : 28/07/2016 8:05 pm
I'm going for the tile option - £30 to cover the floor (Halfords). Putting cardboard underneath is a good suggestion too.
Posted : 28/07/2016 8:32 pm
