any way to get a st...
[Closed] any way to get a stuck limit screw working?
[#2700817]
Bought a 2nd hand front road shimano mech and setting up I've found the outer limit screw is solid, won't move either way. Means that it rubs when in big ring and smallest cog 🙁 any good bodges out there?
Posted : 28/04/2011 7:28 pm
Pour boiling water over it very slowly and then try.
Posted : 28/04/2011 7:32 pm
I like singing this song at full volume when I'm adjusting my limit screw, maybe it could work for you.
Posted : 28/04/2011 7:36 pm
no joy with the water 🙁
Posted : 28/04/2011 8:53 pm
Immense heat, extreme cold, brute force, frustration, strop, power tools , strop then a hammer 😉
soak it in oil for a few days to see if it gets lubed up enough to move. Then try it drill it but possibility of damage to the mech
Good Luck
Posted : 28/04/2011 8:56 pm
I've solved similar issues with application of 'Plus Gas' and patience; apply and wait.
It's not a fossil fuel (thoughy probably burns if ignited) but an effective penetrating fluid.
Posted : 29/04/2011 7:08 am
