Any GPS experts abo...
[Closed] Any GPS experts about? Course not visible on a Garmin 800 (Connect/ Mapmyride)
 DanW
Hi all,
I've tried to make a route on Garmin Connect and also Mapmyride, exported as a .gpx and then copy/ pasted the file to the courses folder of my Garmin Edge 800. The problem is that it doesn't show up on the list of courses once browsing on the Garmin unit itself.
What am I missing? ๐Ÿ™‚
Many thanks, DanW
Posted : 22/04/2015 3:43 pm
I think you need to put it in a folder called 'new' or something. I will just take a look.
Posted : 22/04/2015 4:19 pm
Copy the GPX file you exported into the Garmin\NewFiles folder on the Edge 800. The unit picks it up from there.
Posted : 22/04/2015 4:22 pm
 DanW
Ah ha! Perfect now ๐Ÿ™‚ I've had the Garmin 3 years or so now and never noticed the New folder let alone given any thought as to how to use it!
Posted : 22/04/2015 4:31 pm
And if you want to protect the course in case the gps crashes there is the same folder on the sd card that you can also use.
Posted : 22/04/2015 8:03 pm
