Any got a 36mm span...
[Closed] Any got a 36mm spanner I could borrow...Redditch or Coventry.
Random I know but doing a project bike for my 3yr old lad. The BB cup is seized and it’s the oval 36mm slot type. My adjustable spanner won’t work. I appreciate I can buy a proper tool for £15 but don’t expect to ever need a 36mm spanner again!
On the off chance someone local has one that would be awesome. Cheers very much
Posted : 20/01/2019 10:48 pm
Good luck getting that off.
Heat and a vice might be more use.
Can you not just pack it with grease and new bearings?
Posted : 20/01/2019 10:50 pm
Is there enough room to clamp it in a vice and turn the frame. That tends to be the most successful way to loosen and old, siezed bottom bracket.
Posted : 20/01/2019 10:54 pm
Park tool HCW-4 would be ideal
Posted : 20/01/2019 11:04 pm
having a similar dilemma, I just found an adjustable in B&M that goes up to 55mm for less than £7
and stanley do one that does 65mm for the same price but I dont recall where
Thanks all. Want to remove it so the frame can be powder coated.
Vice clamp tomorrow me thinks!
Posted : 20/01/2019 11:05 pm
I'd go with vice and a bit of warming with a hot air gun.
If you go the spanner or HCW-4 tool then use a g-clamp and some bits of wood to clamp the spanner on so it can't slip off. I've got loads of 36mm spanners at work but unfortunately too far away to be of assistance.
Posted : 20/01/2019 11:08 pm
Thanks all. Found that my adjustable wrench just keeps slipping.
Heat - should I heat the cup itself or the BB shell itself?
Posted : 20/01/2019 11:11 pm
Obvious I know, but you are turning it the correct direction?
Posted : 20/01/2019 11:16 pm
Haha...that was my first worry Onzadog! I double checked with Park tool:
Righty righty
Posted : 20/01/2019 11:18 pm
heat expands so heat the frame
Posted : 21/01/2019 11:54 am
Sorted! Vice was a winner.
Thanks all
Posted : 21/01/2019 9:41 pm
