Any good deals on f...
[Closed] Any good deals on forks about
After some new forks for my voodoo bizango, the suntour radion are generally OK but starting to get very noisy with top out knock and blow through the travel. Don't need anything top of the range, ideally 1/18 but can go taper with a change of headset cup. 130mm travel, 29er 100x15mm axle spacing
What's out there
Thanks
Posted : 28/04/2020 10:37 am
I have an x fusion mcqueen RL2 I'll be putting on classifieds soon if you're interested? It's a tapered steerer and boost spacing so might not be ideal. Maybe you can get hub adapters for boost spacing?
Posted : 28/04/2020 2:40 pm
At the moment in trying to avoid boost. Its a superstar v6 hubs and they don't do any end caps to convert it so would be the washer type adapter, the v6 front hub is a pain to fit at the best of times with its loose fitting end caps
Thanks for the offer regardless
Posted : 28/04/2020 8:15 pm
If you do pursue boost adaptors then Alltricks have 130mm Reba’s for less than £250 delivered. I recently got some and they arrived really quickly.
https://www.alltricks.com/F-11918-fourches/P-405824-rockshox_reba_rl_solo_air_29_____boost_15x110mm_offset_51___black_2019
Posted : 29/04/2020 4:19 am
