Any frame with hori...
[Closed] Any frame with horizontal dropouts and mech hanger but NOT AN INBRED!!!
Hi, I'm looking for a 26" wheel mtb frame that can be run either singlespeed or geared.
I don't want an on one inbred tho!!!!
I'm struggling to get hold of an orange p7 pro too so thats off the list.
Whats on the market?
Any ideas would be great!
Sam
Posted : 28/01/2013 9:08 pm
Decade Virsa.
I have one for sale, as it happens 🙂
Posted : 28/01/2013 9:10 pm
 IanW
Scandal ?
Posted : 28/01/2013 9:12 pm
there are quite a few frames with vertical but adjustable drop outs with hanger. eg Voodoo, Kinesis, Salsa etc etc (don't know the exact names though)
Oh yeah?
send some info to rockymerlin@btinternet.com if you would be so kind please.
I'm after a 17/18"
Fire Eye Flame cheap on CRC?
NS surge
Posted : 28/01/2013 9:13 pm
Ygm rockymerlin
Posted : 28/01/2013 9:17 pm
I have some chain tugs with built in gear hangers so if you run a frame with track ends you can still run gears
@ the podge, what do you call the said chain tugs, sounds interesting
Posted : 28/01/2013 9:31 pm
These are the bad boys he's on about,
i've used them in the past work a treat but you'll need a full length cable if no cable routing.
The front mech can also be problematic if no routing.
Posted : 28/01/2013 9:38 pm
Lovely, i'm not too fussed about a front mech, do those tugs have a name/ locatin to be purchased?
Posted : 28/01/2013 9:39 pm
Mine look a bit different but the principal is the same, you can have 'em for a fiver if you like
 MSP
Pipedream Sirius R853
Posted : 28/01/2013 9:41 pm
surly karate monkey
Posted : 28/01/2013 9:50 pm
Will the tugs take a 10mm bolt thru axle per chance?
Posted : 28/01/2013 9:53 pm
just seen one come up on classifieds?
Posted : 28/01/2013 10:13 pm
They are DMR chaintug / mech hangers, list price is about £20 a pack. I've just got some for an Inbred 29er SS frame. They should take a 10mm bolt through as they are for 10mm axle. Might be a length issue as they effectively make the dropouts significantly thicker, so probably best to check with DMR.
Posted : 28/01/2013 10:42 pm
