Any ever replaced t...
Any ever replaced the pad in a pair of good quality cycling shorts
I have a pair of really nice quality Le Col road shorts. Easily my best shorts. Comfy and well-made.
Had them about four years, so no complaints. But all of a sudden, the pad has just given up. Split into various parts and rearranged itself under one cheek.
Anyone ever got a pad replaced in shorts? Of course, I could just bin them, but as the rest of the (pricey) shorts are still in great condition, it feels like a waste.
Posted : 05/10/2024 12:56 pm
By the time the pad goes mine have usually also gone a bit too transparent and chipolata.
Rather than bin I might use them for short sessions on the trainer, but not for outdoors
Posted : 05/10/2024 1:30 pm
cookeaa and cookeaa reacted
A local tailor might be able to add a new chamois in...probably would need it supplied though.
Does the manufacturer do a repair service?
Posted : 05/10/2024 2:27 pm
Yeah, mine too. I suggest the OP asks one of his good cycling buddies to ride behind him on a sunny day to check just how translucent his shorts have become 😉
Posted : 05/10/2024 5:55 pm
in my own, admittedly fairly irrelevant experience, I’d end up spending almost the cost of a new pair, and then something else would break within about a week of the repair, making it all pointless! Like a zip failing, or a tear in the bum.
Posted : 05/10/2024 6:12 pm
It’s a long shot, but it would be worth contacting le Col and see if they’ll repair/replace, given the cost it’s a reasonable ask, the worst they can do is say no!
Posted : 05/10/2024 8:43 pm
Simply squirt expanding foam all over your arse then pull the shorts on quickly. Allow to dry.  Et Voila, new chamois.
Thanks not necessary
Posted : 05/10/2024 9:42 pm
BITD the pro riders would have a preferred pad and when team kit was issued they'd get a seamstress to remove the issued pads and replace with their preferred design, so it is definitely feasible to do, but it might be tricky finding a quality pad that is sold on its own. This company makes pads but don't know if you can buy them seperatly : https://www.elasticinterface.com/brands/ and you can get cheap ones off Amazon https://www.amazon.co.uk/WOSAWE-Cycling-Breathable-Shockproof-Underwear/dp/B07TLJ5Y8X
Posted : 06/10/2024 11:24 am
While I'm all for repairing stuff as far as possible, it seems* to me that the pad is the critical part, and probably where all the value is, so shoehorning something else in is just going to be disappointing. Replacing the pad with a cheap one off Amazon seems like keeping your favourite bike by replacing the snapped frame with something from Halfords.
Yeah, maybe ask Le Col, but I doubt they could repair it economically. They might offer you a discount off a new pair. I'd just be happy you've found some shorts compatible with your derriere, whatever the cost.
*No pun intended
Posted : 06/10/2024 11:39 am
 igm
Make sure you get a good tailor / seamstress.
A badly fitted pad will certainly result in the blues
Posted : 06/10/2024 12:21 pm
Excellent responses here.
Thanks all!
Posted : 06/10/2024 9:04 pm
