Any deals about for...
[Closed] Any deals about for 100mm 29er forks?
Anyone seen anything? Checked the obvious online stores and the German sites but nothing stands out. Or maybe forks are just big money these days.
<span style="font-size: 0.8rem;">Looking for tapered with bolt through axle, non boost. Recon/Reba would be fine.</span>
Ta
Posted : 09/10/2018 8:03 pm
 a11y
http://www.chainreactioncycles.com/mobile/rockshox-rs1-acs-solo-air-forks-2016/rp-prod136311
Although “A "predictive Steering" hub is also required for use with these forks, due to the toothed dropouts”
Posted : 09/10/2018 8:17 pm
Cheers, anyone seen anything else?
Posted : 10/10/2018 2:38 pm
Second hand? I have a set of Rebas here, set at 120 but can be dropped to 100. Nice long steerer still and 15mm maxle. I have them looked open as the bar mounted lock-out is useless so I took it off. Could be converted to a fork mounted lock out or use as is.  Otherwise all in good condition with just normal marks from use, paint rub from mudguards etc. Can do photos if interested. <span style="font-size: 0.8rem;">Could do them for £100 plus postage</span>
Posted : 10/10/2018 3:08 pm
Have just ordered these for £277  :  http://www.chainreactioncycles.com/fr/en/rockshox-sid-rl-solo-air-forks-boost-2017/rp-prod174786
But 29" version is only selectable for the "list of options", so not sure if they are actually in stock.. will find out in a couple of days!
(they're boost, but I'll buy a conversion kit for the wheel if they actually turn up)
Posted : 10/10/2018 4:45 pm
Thanks all, sorted now!
Posted : 10/10/2018 8:26 pm
